Label halo while superimposing on Google Layer
2112
09-01-2014 09:38 PM
AbhijatC
I had developed a web portal using ArcGIS 10.2. Google Layer is added through agsjs.layers.GoogleLayer and a mxd made by ArcMap is superimposed by adding it in the map layer levels. The issue is that the labels display perfect when part of which is above the mxd but when the labels comes over satellite view of google view the label gets a white shadow. How to remove it? Snapshot is attached for the issue generated.
