JSON not loading in dev environment
502
09-28-2021 12:21 PM
lakshmanankrishnan
I am using the JavaScript API within a Vue CLI project. I get the following errors when the attribution, zoom, and pop up widgets load. These errors popup only when I use the the dev server that is provided with Vue CLI.
The above errors go away when the project is built and served on a web sever like IIS/Apache.
I understand this is a MIME type issue. What can I do to get these errors go away in my dev environment?
ReneRubalcava
Are you trying to copy the assets locally? Can you provide a repo app, you might need to play with the config.assetsPath if you want the assets locally. Here is a demo app using vue3, the JSAPI and local assets.
https://github.com/odoe/vue-jsapi-calcite
I haven't run into MIME type issue with the cli server before, it's usually how the assets are being copied and referencing them correctly.
ReneRubalcava
lakshmanankrishnan
It ended up being an assetspath issue. I have fixed it. Thanks.
-lak krishnan
