JSAPI Feature layer created from feature collection and the feature table
2996
03-08-2016 01:46 PM
CorySchinkel1
I'm currently working on creating a feature layer from a feature collection and then creating a feature table based on the feature layer (that's a mouthful!).  This all works, except that when I select a row in the feature table the following error shows in the console.  Does anyone know if this setup is supported?  I am using 3.16 of the API.  Here is a link to a demo of what I am trying to accomplish.  http://plnkr.co/edit/4k1gdO?p=preview
TypeError: Object doesn't
support property or method 'emit' TypeError: Object doesn't support property or
method 'emit'
   at Anonymous
function (http://js.arcgis.com/3.16/esri/dijit/FeatureTable.js:74:136)
   at c (https://js.arcgis.com/3.16/:66:215)
   at then (https://js.arcgis.com/3.16/:68:301)
   at b.then (https://js.arcgis.com/3.16/:1038:300)
   at Anonymous
function (http://js.arcgis.com/3.16/esri/dijit/FeatureTable.js:73:329)
   at Anonymous
function (https://js.arcgis.com/3.16/:167:287)
   at k (https://js.arcgis.com/3.16/:189:425)
   at b.then (https://js.arcgis.com/3.16/:192:308)
   at Anonymous
function (http://js.arcgis.com/3.16/esri/dijit/FeatureTable.js:73:213)
   at Anonymous
RobertScheitlin__GISP
Cory,
   There was a massive overhaul of th FeatureTable in 3.16. So my first advice is to try it in 3.16.
CorySchinkel1
Thanks Robert.  This was working prior to 3.16 but I was hoping to leverage some of the overhaul, but I guess that might have to wait if 3.16 is fully baked.
JillianStanford
Hi Cory,
Did you every find an answer to this? I'm having the same issue at 3.16.
Jill
