JSAPI 4.3 vs 4.6 Legend Widget "visible" property
1490
01-16-2018 10:50 AM
PhilipGriffith
New Contributor III
I originally wrote some code using the 4.3 Javascript API to make the Legend widget visible only at certain scales of the map view:
var legend = new Legend({
    view: mapView,
    layerInfos: [{
      layer: myLayer,
      title: "My Title"
    visible: false
 mapView.watch("scale", function(scale) {
   if (scale > 1500000) {
    legend.visible = false;
   } else {
    legend.visible = true;
When using version 4.3 of the Javascript API, this code works: the Legend changes its visibility at the appropriate scale.
When using version 4.6 of the Javascript API, this code breaks: the Legend always remains visible, but switches between displaying the layer properties and displaying "No legend," rather than disappearing as it did before.
How can I mimic the functionality of 4.3 in version 4.6?
Thanks for the help!
Philip
RobertScheitlin__GISP
Phillip,
   you can use this:
          view.watch("scale", function(scale) {
            legend.container.style.display = 'none';
           } else {
            legend.container.style.display = '';
Phillip,
   you can use this:
           } else {
PhilipGriffith
New Contributor III
That works. Thanks for the quick solution, Robert!
PhilipGriffith
New Contributor III
Actually, one last question: is there a way to initialize the Legend widget so that it has its display set to 'none'?
Currently, the map loads and the "No legend" box is present until the user changes scales.
I'm having trouble accessing the display property when creating the Legend widget.
Thanks again for the help!
Philip,
   That would involve using watchUtils. Here is a sample:
<!DOCTYPE html>
<html>
<head>
  <meta charset="utf-8">
  <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
  <title>Legend widget - 4.6</title>
  <link rel="stylesheet" href="https://js.arcgis.com/4.6/esri/css/main.css">
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
      overflow: hidden;
  </style>
  <script src="https://js.arcgis.com/4.6/"></script>
  <script>
    require([
        "esri/views/MapView",
        "esri/widgets/Legend",
        "esri/WebMap",
        "esri/core/watchUtils",
        "dojo/domReady!"
      function(
        MapView, Legend, WebMap, watchUtils
        var webmap = new WebMap({
          portalItem: { // autocasts as new PortalItem()
        var view = new MapView({
          container: "viewDiv",
          map: webmap
        view.when(function() {
          // get the first layer in the collection of operational layers in the WebMap
          // when the resources in the MapView have loaded.
          var featureLayer = webmap.layers.getItemAt(0);
            view: view,
            layerInfos: [{
              layer: featureLayer,
              title: "NY Educational Attainment"
          watchUtils.when(legend ,"container", function(){
          // Add widget to the bottom right corner of the view
          view.ui.add(legend, "bottom-right");
           } else {
            legend.container.style.display = 'block';
  </script>
</head>
<body class="calcite">
  <div id="viewDiv"></div>
</body>
</html>
PhilipGriffith
New Contributor III
Got it. Thanks again, Robert!
