JSAPI 4.10: Popup Actions now under "..." button
2325
6
01-09-2019 01:34 AM
KevinHaeni
New Contributor III
Starting from JSAPI 4.10, all custom actions are now shown under a "..." menu button, which isn't a bad thing, but I think there should be a changable threshold value, for example:
3 actions --> Buttons are directly shown
5 actions --> Buttons appear under "..."
Right now, we have 2 actions (which could be easily displayed as separate buttons), but the user first has to open the menu to find them.
Is there any workaround? Since the markup is removed from the DOM while the menu button isn't toggled, it cannot be done using CSS.
Tags (1)
KellyHutchins
Esri Frequent Contributor
Kevin,
At 4.10 you can't override this behavior but at the next release we are going to add a way to either set a threshold or an option to disable the menu.
Kelly]
GregMcNamee
New Contributor III
So can you set a threshold or disable this behavior in 4.11? Trying to find in documentation...
Thanks.
Greg McNamee
GregMcNamee
New Contributor III
Nevermind. view.popup.actionsMenuEnabled = false;
Greg McNamee
KellyHutchins
Yep actionsMenuEnabled is what you need. You can use it to show/hide the menu based on the number of actions the selected feature's popup template contains
  view.popup.watch("selectedFeature",(graphic)=>{
     const template =graphic.getEffectivePopupTemplate();
     template.actions.length > 3 ? view.popup.actionsMenuEnabled=true : view.popup.actionsMenuEnabled=false;
JackFairfield
Occasional Contributor II
Why do the popup action buttons overlap the feature navigation arrows?  This looks like a bug to me.
Try clicking so that multiple features are selected in this sample:
https://developers.arcgis.com/javascript/latest/sample-code/sandbox/index.html?sample=popup-actions
RobertScheitlin__GISP
Jack,
    This is a bug in 4.11. It will be fixed in 4.12. Until then here is a workaround:
https://community.esri.com/thread/233307-how-to-configure-popup-actions-buttons-in-411#comment-85051...
