JS API - Convert Easting/Northing to Latitude/Longitude
2099
07-11-2019 02:13 AM
ScottWilson2
New Contributor II
How do i convert Easting and Northing to Latitude and Longitude using the JavaScript API?
I have a rest service which returns an array of objects, each object contains geometry x and y coordinates, i believe this is Easting and Northing
var items = [{
 "attributes": {
   "OBJECTID": 18342
 "geometry": {
   "x": 250067.50299999956,
   "y": 659477.8800000008
I'm using the Point class to try and pin each coordinate to my map, but i believe this class requires latitude and longitude format: https://developers.arcgis.com/javascript/3/jsapi/point-amd.html
Using 3.28
thanks
RobertScheitlin__GISP
Scott,
   The APIs Point class does not require the Latitude and Longitude. You can provide X and Y in any coordinates system as long as you specify the SpatialReference for the Point. I.E. new Point(x, y, spatialReference). So you need to know your data spatial reference. If you are adding this data to a map that is using different SpatilalReference then you will have to Project your data to WKID 102100 WebMercator. https://developers.arcgis.com/javascript/3/jsapi/geometryservice-amd.html#project
ScottWilson2
New Contributor II
Hi Robert, thanks for your help.
I have spoken to our GIS professional and they advised that we are using British National Grid (27700).  I have added this SpatialReference to my map and the points are now displaying, albeit of the coast of Nigeria!
var point = new Point(items[key].geometry.x, items[key].geometry.y, new SpatialReference({ wkid: 27700 }) );
I guess i need to project my data to WebMercator but even after looking at the documentation link you provide, i'm still not exactly sure how i code this
thanks
Scott
Scott,
   It is not to hard.
var gsvc = new GeometryService("https://utility.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer");
var params = new ProjectParameters();
params.geometries = [point];
params.outSR = map.spatialReference;
gsvc.project(params, function(results){
    // do something with the results here
