JS API 4.X: ViewPoint.targetGeometry only works with Point
459
03-13-2019 04:18 PM
NicolasGIS
Occasional Contributor III
Hello,
I just noticed that the viewPoint.targetGeometry can only be a Point as it fails silently when it is a polygon or a polyline:
Codepen
Is it a bug or type definition error ?
Thanks
Tags (1)
RobertScheitlin__GISP
Nicholas,
  That does seems like a bug. Though I am not sure why you would do that vs using goTo with the target of polygonGraphic.geometry and scale of 1000000?
      view.when().then(() => {
        view.goTo({
          target: polygonGraphic.geometry,
          scale: 1000000
NicolasGIS
Hello Robert,
Thanks for the reply.
I am doing that because I have a function that depending on parameters return viewPoint accordingly.
I will use your workaround in the meantime.
Thanks !
