I am looking for JavaScript API (js.arcgis.com/4.15) that enables to get the map visible area.
Hence, the X,Y coordinates of the visible area (polygon or rect coordiantes) of the presented map.
In android arcgis SDK there is method getVisibleArea() that does it
Google Map api provides it as:
var visibleRegion = googleMap.projection
visibleRegion.farRight.latitude, visibleRegion.farRight.longitude, visibleRegion.nearLeft.latitude, visibleRegion.nearLeft.longitude
I've made some expirimates retrieve it from
let view = new MapView({
container: "viewDiv",
map: map,
zoom: 7,
center: [-117.295800, 34.076295], // longitude, latitude, centered on Austria
constraints: {
minZoom: 16 // Use this constraint to avoid zooming out too far
view.when(function() {
let initialExtent = view.extent;
let height = initialExtent.height;
let mmax = initialExtent.mmax;
let mmin = initialExtent.mmin;
let type = initialExtent.type;
let width = initialExtent.width;
let xmax = initialExtent.xmax;
let xmin = initialExtent.xmin;
let ymax = initialExtent.ymax;
let ymin = initialExtent.ymin;
However the numbers I get are not coordinates at all:
xmax: -13055474.239510546
xmin: -13059143.216868332
ymax: 4039950.5164796906
ymin: 4038151.857657808
Also, try to convert it to Polygon doesn't help:
var polygon = Polygon.fromExtent(initialExtent);
The polygon ring attribute contains the exact same values as above ... so it doesn't help at all.
I have no idea how they can be converted to the top right/left/top/bottom coordinates of the presented map. Maybe this is not the correct approach, however this is as far as I could get.
I've looked all over in MapView for getVisibleArea() and couldn't find,
Thanks.
BTW , in order to change the extent to WGS84 it is much easier to use webMercatorUtils and there's no need to load the projections.
Dear @kerenc ,
Thank you so much for the solution. For the sake of other who straggle the exact same, here is the complete code below.
Best,
Gabriel
<!DOCTYPE html>
<html>
<head>
<meta charset="utf-8">
<meta name="viewport" content="initial-scale=1, maximum-scale=1, user-scalable=no">
<title>ArcGIS API for JavaScript Tutorials: Create a JavaScript starter app</title>
<style>
html, body, #viewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
</style>
<link rel="stylesheet" href="https://js.arcgis.com/4.15/esri/themes/light/main.css">
<script src="https://js.arcgis.com/4.15/"></script>
<script>
require([
"esri/Map",
"esri/views/MapView",
"esri/layers/GraphicsLayer",
"esri/Graphic",
"esri/geometry/Polygon"
], function (Map, MapView, GraphicsLayer, Graphic, Polygon) {
var map = new Map({
basemap: "topo-vector"
var mapView = new MapView({
map: map,
zoom: 16
var graphicsLayer = new GraphicsLayer();
const point = {type: "point", longitude: -117.295800, latitude: 34.076295};
const pointPicture = {type: "point", longitude: -117.298800, latitude: 34.077295};
const simpleMarkerSymbol = {type: "simple-marker", color: [226, 119, 40]};
const pictureSymbol = {
type: "picture-marker", // autocasts as new PictureMarkerSymbol()
url: "https://static.arcgis.com/images/Symbols/Shapes/BlackStarLargeB.png",
width: "64px",
height: "64px"
var pointGraphic = new Graphic({geometry: point, symbol: simpleMarkerSymbol});
var pointPictureGraphic = new Graphic({geometry: pointPicture, symbol: pictureSymbol});
graphicsLayer.add(pointGraphic);
graphicsLayer.add(pointPictureGraphic);
map.add(graphicsLayer);
mapView.when(function(){
console.log("Map is ready")
}, function(error){
// This function will execute if the promise is rejected due to an error
mapView.watch('extent',getProjection)
function getProjection(camera) {
console.log("getProjection: started")
if(camera.extent.xmin == undefined)
return;
const initialExtent = mapView.extent;
const webMercatorUtils = require("esri/geometry/support/webMercatorUtils");
console.log("getProjection: webMercatorUtils = "+webMercatorUtils)
const nePoint = webMercatorUtils.xyToLngLat(initialExtent.xmin, initialExtent.ymin)
const swPoint = webMercatorUtils.xyToLngLat(initialExtent.xmax, initialExtent.ymax)
console.log("Map projection north east point is: "+nePoint)
console.log("Map projection south west point is: "+swPoint)
</script>
</head>
<body>
<div id="viewDiv"></div>
</body>
</html>
You can use a projection to convert to coordinates to lat/lon.
You want the convert to WGS84 to get lat/lon. Use WGS84 to get an instance of that projection.
(Check the "see also" links on the projection page for the details)
Thank you for your quick response 🙂
I wish to validate I well understood the solution:
<!DOCTYPE html>
<html>
<head>
<meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
<title>Limit MapView to Certain Area - ArcGIS JavaScript 4.15</title>
<link rel="stylesheet" href="https://js.arcgis.com/4.15/esri/css/main.css">
<style>
padding: 0;
margin: 0;
height: 100%;
width: 100%;
</style>
<script>
require([
"esri/Map",
], function(Map, MapView) {
let map = new Map({
basemap: "streets"
map: map,
zoom: 7,
constraints: {
getProjection(view);
function getProjection(view) {
const Projection = require("esri/geometry/projection");
const SpatialReference = require("esri/geometry/SpatialReference");
const initialExtent = view.extent;
const geogtrans = Projection.getTransformations(SpatialReference.WGS84, SpatialReference.WGS84, initialExtent);
geogtrans.forEach(function(geogtran, index) {
geogtran.steps.forEach(function(step, index) {
console.log("step wkid: ", step.wkid);
</script>
</head>
<body>
</body>
</html>
I have runtime error:
Uncaught (in promise) TypeError: Cannot read property '_getTransformationBySuitability' of null
at Object.a.getTransformations (mapViewDeps.js:45)
at getProjection (sample.html?_ijt=feaunen6peg1167143od9in19e:46)
It doesn't understand how to handle Projection. Projection type doesn't have a constructor as I could see.
Also, I am not sure I understand how to extract the latitudes and longitudes from the geogtrans variable.
@VictorBerchet can you please assist in fix my sample above and point were Lon and Lat within the geogtrans?
Thank you very much.
<!DOCTYPE html>
<html>
<head>
<meta charset="utf-8" />
<meta
name="viewport"
<link
rel="stylesheet"
href="https://js.arcgis.com/4.18/esri/css/main.css"
<script src="https://js.arcgis.com/4.18/"></script>
<style>
html,
body,
#viewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
</style>
<script>
require([
"esri/Map",
"esri/geometry/projection",
], function (Map, MapView, Projection, SpatialReference) {
let map = new Map({
basemap: "streets"
map: map,
zoom: 7,
center: [-117.2958, 34.076295], // longitude, latitude, centered on Austria
constraints: {
//view.when(function () {
// getProjection(view);
view.watch('extent',getProjection)
return;
const projection = require("esri/geometry/projection");
//projection = new Projection();
projection.load().then(function() {
console.log("projection.load()");
debugger;
projection.getTransformations(
new SpatialReference(2039),
initialExtent
).then(function(geogtrans){
geogtrans.forEach(function (geogtran, index) {
geogtran.steps.forEach(function (step, index) {
</script>
</head>
<body>
</body>
</html>
I tried to do minimal changes to your code to make it work.
Notice that I've added the load method to projection class and I watch the extent in order to use it only after it is populated with value (better change the code to change it once or skip the load when it is loaded).
Any way it has no logic to get transformations from 2 exact same projections so that it returns an empty array on my sample code - try to use to different projections...
Good luck
Thank you @kerenc for your assistance.
Code fails during runtime:
projection.load()
esri.html?_ijt=b7g5ecd5goqr8hnarkbpa2atn5:66 Uncaught (in promise) TypeError: projection.getTransformations(...).then is not a function
at esri.html?_ijt=b7g5ecd5goqr8hnarkbpa2atn5:66
Can you please advise how to fix?
Also, I am not fixed with specific method for getting map projection. Also tried GeometryService that failed since require("esri/tasks/GeometryService") gives Error: undefinedModule ... however here is the code:
require([
"esri/Map",
let map = new Map({
basemap: "streets"
map: map,
zoom: 7,
constraints: {
return;
const Point = require("esri/geometry/Point");
const GeometryService = require("esri/tasks/GeometryService");
const ProjectParameters = require("esri/tasks/support/ProjectParameters");
var pointTopRight = new Point(initialExtent.xmin, initialExtent.ymin, map.spatialReference );
var pointBottomLeft = new Point(initialExtent.xmax, initialExtent.ymax, map.spatialReference );
var gsvc = new GeometryService("https://utility.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer");
var params = new ProjectParameters();
params.geometries = [pointTopRight, pointBottomLeft];
params.outSR = map.spatialReference;
gsvc.project(params, function(results){
console.log(results)
(index):32 Uncaught Error: undefinedModule
at n ((index):32)
at Z ((index):39)
at d ((index):32)
at getProjection (esri.html?_ijt=b7g5ecd5goqr8hnarkbpa2atn5:59)
@kerenc As you could see I've tried to solve the problem from different angels, so far no success.
I thought that the question of getting the boudries coordinates (Lat, Lon) of a map view should be fundamental. I hoped to find a straightforward way to get it.
Thanks for your kind help, any solution that can provide the mapView Lon/Lat visible area projection is most Wellcome. Looking forward your respone.
Best,
Gabriel
You really do not need all those lines to get the visible area, you can watch the view's extent and get it.
Esri's help samples has is a nice sample that demonstrates it: https://developers.arcgis.com/javascript/latest/sample-code/watch-for-changes/index.html
In order to get the spatial reference just read view.extent.spatialReference
Regarding your code fix, I apologize, At first glance, I thought that it failed because the method returns a promise and after reading the api reference I realized you were missing the call to projections.load().
I forgot to change it back.
Here is the fixed code:
<!DOCTYPE html>
<html>
<head>
<meta
name="viewport"
<link
rel="stylesheet"
<style>
html,
body,
#viewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
</style>
<script>
require([
"esri/Map",
let map = new Map({
basemap: "streets"
map: map,
zoom: 7,
constraints: {
view.watch("extent", getProjection);
if (camera.extent.xmin == undefined) return;
projection.load().then(function () {
geogtrans = projection
new SpatialReference(3636),
initialExtent
</script>
</head>
<body>
</body>
</html>
Dear @kerenc ,
Best,
Gabriel
<!DOCTYPE html>
<html>
<head>
<style>
padding: 0;
margin: 0;
height: 100%;
width: 100%;
</style>
<script>
require([
"esri/Map",
"esri/Graphic",
var map = new Map({
map: map,
zoom: 16
width: "64px",
height: "64px"
}, function(error){
return;
</script>
</head>
<body>
</body>
</html>
