Hi Esri Community,
We run into a problem, We generate the Custom Maps and try to implement the "Print" API with "Print Templates" that listed in documentation here:
https://developers.arcgis.com/javascript/latest/api-reference/esri-rest-print.html
When we implement the JavaScript Request but it's give Error "(index):23 Uncaught ReferenceError: execute is not defined"
I checked the Documentation and there is noting to add anything in the Require for Execute.
Here is the Code Example that we are using:
<link rel="stylesheet" href="https://js.arcgis.com/4.20/esri/themes/light/main.css">
<script src="https://ajax.googleapis.com/ajax/libs/jquery/3.5.1/jquery.min.js"></script>
<script src="https://js.arcgis.com/4.20/"></script>
require([
"esri/config",
"esri/Map",
"esri/views/MapView",
"esri/layers/FeatureLayer",
"esri/layers/MapImageLayer",
"esri/identity/OAuthInfo",
"esri/identity/IdentityManager",
"esri/Basemap",
"esri/layers/VectorTileLayer",
"esri/layers/TileLayer",
"esri/rest/print",
"esri/rest/support/PrintTemplate",
"esri/rest/support/PrintParameters",
"esri/tasks/QueryTask",
"esri/rest/query"
], function(esriConfig, Map, MapView, FeatureLayer, MapImageLayer, OAuthInfo, esriId, Basemap, VectorTileLayer, TileLayer, Print, PrintTemplate, PrintParameters, QueryTask, Query) {
We create our Maps like this:
// Income Map
var map = new Map({ basemap: "arcgis-topographic" });
var view = new MapView({ map: map, center: [-94.7148669, 38.9065419], zoom: 14, container: "viewDiv2" });
const income_main = new MapImageLayer({ portalItem: { id: "ID" } });
map.add(income_main);
esriConfig.request.interceptors.push({ urls: Zipcode_Layer, before: function (params) {
params.requestOptions.query = params.requestOptions.query || {};
params.requestOptions.query.token = access_token; },});
var zipcode = new FeatureLayer({
url: Zipcode_Layer
map.add(zipcode);
After Map Creation we implement this code for Print API:
var url55 = "https://utility.arcgisonline.com/arcgis/rest/services/Utilities/PrintingTools/GPServer/Export%20Web%20Map%20Task/execute";
const template = new PrintTemplate({
format: "png",
exportOptions: {
dpi: 300
layout: "a4-portrait",
layoutOptions: {
titleText: "Gillette Stadium",
authorText: "Thomas"
const params = new PrintParameters({
view: view,
template: template
// execute(url50, params).then(printResult).catch(printError);
execute(url55, params).then(printResult).catch(printError);
But it's give an error "(index):23 Uncaught ReferenceError: execute is not defined" Is there anyone who can help to fix the problem...
Thank You
Solved! Go to Solution.
Not sure, but this works
It would look like this.
require([
"esri/rest/print"
], function(print) {
print.execute(url, params);
The execute method exists on the print module you imported.
The code snippet in the doc assumes you are using ES6 import syntax.
import { execute } from "@arcgis/core/rest/print";
Hi Rena Rubalcava, Thanks for your answer when I implement the code that you provide it's bypass that problem but still giving error
"Error executing tool. Export Web Map Task : Required 'mapOptions.extent' property missing from web map JSON. Failed to execute (Export Web Map). Failed to execute (Export Web Map Task)."
Ok, I checked this out. "png" is not a format option. It's png8 or png32. Change that and it should work.
I even added the Extent in the Map as well.
var view = new MapView({ map: map, extent: { xmin: -9177811, ymin: 4247000, xmax: -9176791, ymax: 4247784, spatialReference: 102100 }, zoom: 14, container: "viewDiv2" });
url: Zipcode_Layer
map.add(zipcode);
var url50 = "https://utility.arcgisonline.com/arcgis/rest/services/Utilities/PrintingTools/GPServer/Export%20Web%20Map%20Task";
format: "PNG32",
exportOptions: {
dpi: 300
layoutOptions: {
view: view,
template: template
var imageExport = print.execute(url50, params);
console.log(imageExport);
@ReneRubalcava Did you check this, Where I already update the PNG and Add the Extent but still giving me error for Extent
