Javascript API, elevation layer query
800
04-11-2020 01:49 AM
ManolisNikolakakis
New Contributor II
Hello!
What I want to do is retrieve the elevation of a known point using ArcGIS javascript 4.14. A working example of an an elevation layer query based on the following https://developers.arcgis.com/javascript/latest/api-reference/esri-layers-ElevationLayer.html#queryE... would be great.
I have a similar piece of code in the following link https://codepen.io/nikolakakis/pen/jObOjEv?editors=1111  I always get the error Failed to query elevation: TypeError: Cannot read property 'wkid' of undefined
I tried with an Elevation layer I uploaded and made it public with the same results.
var layer = new ElevationLayer({
       portalItem: {  // public Elevation layer
Does the
https://developers.arcgis.com/javascript/latest/api-reference/esri-layers-ElevationLayer.html#queryE... example indeed return an error or do I miss something here?
Thanks in advance.
ReneRubalcava
The syntax to create a Multipoint is incorrect.
// Incorrect
new Multipoint(points)
// Correct
new Multipoint({points: points})
Once I fixed that, your codepen sample worked.
ReneRubalcava
// Incorrect
// Correct
ManolisNikolakakis
New Contributor II
Thank you Rene,
much appreciated.
