Issue with Spatial Editing for Point Feature
1343
8
11-26-2016 11:22 PM
NiladriBanerjee
Hi All,
I  am having an issue with the spatial editing for point feature. For the spatial editing we have referred the sample the code given in the example.
ArcGIS API for JavaScript Sandbox
This code is working fine for point feature if we don't change  the position and the style  of the default info window which opens when we click on any feature in spatial editing environment. However if we change the style and position of default window to open in a side panel and in that case moving of point feature is not happening while moving of line and polygon feature is working in the side panel info window. Please refer the attached image with the name of "working.jpg" and "notworking.jpg"
Any help concerning this issue will be highly appreciated.
Niladri Banerjee
GIS Developer
Stesalit Systems Ltd.
Tags (1)
RobertScheitlin__GISP
Niladri,
So are you combining the Popup content in side panel sample with the editing widget sample?
NiladriBanerjee
Hi Robert,
Thanks for your reply. Yes you are right we are combining the Popup content in side panel sample with the editing widget sample. Is that causing the issue?
Niladri
Niladri,
   It could be in how you combined them. Can you post your code?
NiladriBanerjee
Here is the code.
this._map.infoWindow.set("popupWindow", false);
this.initializeSidebar(this._map);
initializeSidebar: function(map){
var popup = map.infoWindow;
connect.connect(popup, "onSelectionChange", function(e){
var edithasClass = $("#editFeature").hasClass("active");
displayPopupContent(popup.getSelectedFeature(),domStyle,menus,DeleteFeature,edithasClass);
//when the selection is cleared remove the popup content from the side panel.
connect.connect(popup, "onClearFeatures", function(){
if(edithasClass==false){
  $("#sidepanelAllPourposeContent").html('');
main.js
$("#editFeature").on('click', function(e) {
$("#editFeature").toggleClass("active");
var stackedAreaLegend = dijit.byId('sidepanelSpatialEditing');
if (stackedAreaLegend) {
  stackedAreaLegend.destroyRecursive(true);
if(edithasClass==true){
initEditing(e,array,Editor,domStyle,menus,i18n,draw);
//functions.js
function initEditing (event,arrayUtils,Editor,domStyle,i18n,draw) {
 //allLayers -- It's a global variable;
          var featureLayerInfos = arrayUtils.map(allLayers, function (layer) {
       return {
              "featureLayer": layer
          var settings = {
            map: map,
            layerInfos: featureLayerInfos
          var params = {
            settings: settings
          var editorWidget = new Editor(params, 'sidepanelSpatialEditing');
          editorWidget.startup();
          //snapping defaults to Cmd key in Mac & Ctrl in PC.
          //specify "snapKey" option only if you want a different key combination for snapping
          map.enableSnapping();
function displayPopupContent(feature,domStyle,menus,DeleteFeature,edithasClass){
var stackedAreaLegend = dijit.byId('sidepanelAllPourposeContent');
if(feature){
var content = feature.getContent();
$("#sidepanelAllPourposeContent").html(content);
        $("#sidepanelAllPourposeHeadingSpan").html('Spatial Editing');
           $("#sidepanelAllPourposeHeadingSpan").html(feature._layer.id);
$("#sidepanelAllPourposeContent" ).accordion();
$("#sidepanelAllPourposeContent").accordion( "destroy" );
if(feature._layer.id!='Photos'){
var mapserviceid = $("#associatedForms").attr("mapServiceId");
var objectId = $("#associatedForms").attr("objectId");
var allLoadedService = JSON.parse(localStorage.getItem('loadedServicesstored'));
var allForms ='<table class="table table-striped table-bordered"><tbody>';
for (var i = 0; i < allLoadedService.length; i++) {
if(mapserviceid == allLoadedService.map_service_id){
if(allLoadedService.forms.length==0){
allForms += '<tr class="clickable desc"><td>No Forms Found.</td></tr>' ;
}else{
for (var j = 0; j < allLoadedService.forms.length; j++) {
allForms += '<tr class="clickable desc" ng-click="showCompleted("'+allLoadedService.forms.form_definition_id+'")" ><td>'+allLoadedService.forms.title+'</td></tr>';
allForms += '</tbody></table>';
break;
$("#associatedForms").html(allForms);
$("#sidepanelAllPourposeContent" ).accordion({
collapsible: true,
active: 2,
heightStyle: "content"
$("#associatedForms").mCustomScrollbar({
scrollButtons:{enable:true},
theme:"minimal-dark"
$("#associatedFormResult").mCustomScrollbar({
$("#gisAttributes").mCustomScrollbar({
var layerId = feature._layer.id;
                new AttributeEditor({graphic:feature, layerId:layerId, exists:true});
$(".sideplanelContent").on("click", function(e) {
                if(e.target.id == 'edit-btn' || e.target.id == 'edit-img') {
e.stopPropagation();
                  //  menus.openAttributeEditor();
/*$(".contentWrapEdit").mCustomScrollbar({
                } else if(e.target.id == 'del-btn' || e.target.id == 'del-img') {
DeleteFeature.DeleteFeature(feature._layer.id,feature);
} else if (e.target.id === 'attachments-btn' || e.target.id == 'attachments-img') {
                    Event.stop(e);
                    openAttachmentsModal();
                } else if(e.target.id == 'form-btn' || e.target.id == 'form-img') {
                    Event.stop(e);
                    openFormsModal();
                } else if(e.target.id == 'cancel-button') {
                    Event.stop(e);
                    map.infoWindow.hide();
$( "#sidepanelAllPourposeContent" ).accordion( "refresh" );
Niladri
Niladri,
   Sorry I can not make sense of the code you posted.
NiladriBanerjee
Hi Robert,
For your better understanding I have simplified the code. In the attachment I have shared three java script files( bootstrapmap.js,main.js,function.js) which we are using for the spatial editing. From the bootstrapmap.js file we are setting default pop up window to false and then we are calling the function "displayPopupcontent()" function of function.js  file and in this function  we have taken the sample code of "https://developers.arcgis.com/javascript/3/sandbox/sandbox.html?sample=popup_sidepanel"
and from main.js we are calling "initEditing()" function of function.js file and in this function we have taken the sample code of
Hope I am able to make you understand the code and still if you have any question please let me know.
Niladri
SarojThapa1
Occasional Contributor III
Hey Niladri,
Are you using the default Geometry Server of ArcGIS? If you have your own Geometry Service, replace the default ArcGIS Geometry Service with yours in the following codes.
esriConfig.defaults.geometryService = new GeometryService("https://utility.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer");  // Replace this with your own Geometry Service.
See if it will work.
Goodluck.
NiladriBanerjee
Hi Saroj,
Thanks for your reply, actually we are using ArcGIS Online services can you please tell me where we will get the geometry service for ArcGIS online?
I would also like to let you know that without using the geometry service we are able to do the spatial editing for line and polygon layer.
Niladri
