Issue with draw toolbar activation
1067
02-06-2019 01:10 AM
Abdul_AzizMuhammad_Abdul_Majid
New Contributor II
I am having issue with the toolbar activation at the line 12 in the below code
toolbar.activate(Draw[tool]);
I am getting this error when checking the web console:
Uncaught TypeError: toolbar.activate is not a function
After further looking/debugging into the developer tool, it seems that the activateTool() function is calling before the createToolbar().
Below is my code sample
map.on('load', createToolbar);
function createToolbar(themap) {
    toolbar = new Draw(map);
    toolbar.on("draw-end", addToMap);
on(dom.byId("point"), "click", activateTool('point'));
on(dom.byId("polyline"), "click", activateTool('polyline'));
function activateTool(toolName) {
    var tool = toolName.toUpperCase().replace(/ /g, "_");
    map.hideZoomSlider();
function addToMap(evt) {
    var symbol;
    toolbar.deactivate();
    map.showZoomSlider();
    switch (evt.geometry.type) {
        case "point":
        case "multipoint":
            symbol = new SimpleMarkerSymbol();
            break;
        case "polyline":
            symbol = new SimpleLineSymbol();
            break;
        default:
            symbol = new SimpleFillSymbol();
            break;
    var graphic = new Graphic(evt.geometry, symbol);
    map.graphics.add(graphic);
Thanks to those that can help and thanks to those that helped with the previous question.
RobertScheitlin__GISP
Abdul,
  What does your codes require array and vars look like (the beginning of your code)?
KevinTientcheu3
New Contributor II
Hello Abdul,
As Robert asked, I am also not sure about why you are using a list on line 12 for Draw. However, playing with the sample code from the ArcGIS API for JavaScript Sandbox I was able to get something that I think is what you are looking for. Below is the edited code from the sandbox. It is different from yours in structure but accomplishes the same thing:
map.on("load", createToolbar);
        //---Define your symbols as needed (marker symbol, lineSymbol, fillSymbol)---//
        function createToolbar() {
          toolbar.on("draw-end", addGraphic);
          // event delegation so a click handler is not
          // needed for each individual button
          on(dom.byId("buttons"), "click", function(evt) {
            if ( evt.target.id === "buttons" ) {
              return;
            var tool = evt.target.id.toLowerCase();
            toolbar.activate(tool);
        function addGraphic(evt) {
          //deactivate the toolbar and clear existing graphics
          // figure out which symbol to use
          var symbol;
          if ( evt.geometry.type === "point" || evt.geometry.type === "multipoint") {
            symbol = markerSymbol;
          } else if ( evt.geometry.type === "line" || evt.geometry.type === "polyline") {
            symbol = lineSymbol;
          else {
            symbol = fillSymbol;
          map.graphics.add(new Graphic(evt.geometry, symbol));
Below is what the HTML might look like:
<div id="buttons">
      <div>Select a shape then draw on map to add graphic</div>
      <button id="Point">Point</button>
      <button id="Polyline">Polyline</button>
 </div>
I hope it helps!
JayakumarPD
hi, this is easy, instead of using the default sample given by esri.
on(dom.byId("buttons"), "click", function (evt) {
map.on("click", function (evt) {
console.log(tool);
var pointCordinates = webMercatorUtils.webMercatorToGeographic(evt.mapPoint);
console.log(pointCordinates);
I have challenge of saving the coordinates into database, for point I have taken like this.  But how to take the coordinates for polyline.
