On some of our maps (typically the ones with a local projection), it fails to load at all and we are getting an error in the console related to the "viewPoint" js file.
I located the issue to be the zoom property when instanciating the MapView.
The workaround I found, is to remove that property and zoom right after.
It was working fine in 4.21.
Thanks.
Hi @MatthieuThery1, can you share a simplified test-app that reproduces the issue? I might be confused, but how can the `zoom` variable be both a valid zoom value and a valid goTo object?
In the new MapView do:
zoom: 1
Play around with the value until you get the desired zoom level.
