Issue in PopupTemplate Content 4.14
7255
11
01-02-2020 02:01 AM
MatthieuThery1
It seems I am now unable to set a class/id etc to a div using the content properties of the popuptemplate. It used to work fine in the 4.13. It's pretty annoying as it means we can't style our popups like we used to and have to keep using 4.13.
Is there a workaround, or a reason why it changed?
Below is a Pen built using one of the API sample. As you can see the class property doesn't come through. If you switch back to 4.13, then it does.
https://codepen.io/mtrsklnkvMM/pen/rNaGEYo
Tags (1)
MattDriscoll
Hello,
In 4.14, we are using a HTML sanitizer (https://github.com/Esri/arcgis-html-sanitizer) which removes some HTML for security purposes. We may be able to do something for this in 4.15.
As an alternative workaround to a HTML string, you can do the following to modify a dom node directly.
var template = {
  content: function(){
    var div = document.createElement("div");
    div.className = "myClass";
    div.innerHTML = "<span>My custom content!</span>";
    return div;
RobertScheitlin__GISP
Matthieu,
  Seems like 4.14 has some popup widget content issues. If you use the https://developers.arcgis.com/javascript/latest/sample-code/sandbox/index.html?sample=popuptemplate-... sample it no longer renders svg either. Best to report your bug to esri tech support.
JackFairfield
Occasional Contributor II
I noticed the same issue.  Please let me know if you end up reporting your bug.  Otherwise, I'll report to tech support.  Thanks.
MattDriscoll
Hello,
var template = {
    return div;
JackFairfield
Thanks for the reply.  This workaround seems to work ok for my use case.  It would have been nice to have this included in the Release Notes (Breaking Changes)
MatthieuThery1
The workaround seems to work for me too. I'll mark the answer as correct.
Using react components to display popups I'm now doing:
template.content = () => {
   const div = document.createElement('div');
   ReactDOM.render(<PopupContent />, div);
   return div;
JayHill
Matt
Can I get some help on getting this old code to work in the new version of the api?
qfaultsPopup = function(feature) {
        var content = "";
        var faultZoneSum = feature.graphic.attributes.Summary;
        if (feature.graphic.attributes.FaultZone) {
            content += "<span class='bold' title='Longitude'><b>Fault Zone: </b></span><span id='faultTip'>{FaultZone}</span><br/>";
            query("#faultSum").html(faultZoneSum);
        // assign click even to fault name so summary goes to Fault Summary panel
        $("#faultTip").click(function (e) {
            // hide visible panels, then show the fault summary panel
            showHideCalcitePanels("#panelLegend", "#collapseLegend");
            query("#customMessage").html(faultZoneSum);
        return content;
MattDriscoll
Hi Jay, it would be something like this:
const popupTemplate = new PopupTemplate({
  content: (event) => {
    const { graphic } = event;
    const container = document.createElement("div");
    if (graphic.attributes.FaultZone) {
        const faultZone = document.createElement("strong");
        faultZone.textContent = "Fault Zone:";
        container.appendChild(faultZone);
        const faultZoneSum = graphic.attributes.Summary;
        const faultTip = document.createElement("span");
        faultTip.textContent = faultZoneSum;
        container.appendChild(faultTip);
        faultTip.onclick = () => {
    return container;
JayHill
Thanks Matt! One question though. I only get the OBJECTID returned on that function in graphic.attributes
MattDriscoll
Hey Jay, I think that is because either the layer you're using needs the `outFields` set on it to define what fields are needed or you can also set the `outFields` on the popupTemplate.
https://developers.arcgis.com/javascript/latest/api-reference/esri-PopupTemplate.html#outFields
