Invoke sketch widget tool from button click?
1832
05-18-2021 07:26 AM
GWReid
New Contributor II
I'd like to invoke a sketch widget tool from a button click as opposed to the widget itself.  Can this be done?
const sketch = new Sketch({
        layer: graphicsLayer,
        view: view,
        creationMode: 'update',
        availableCreateTools: ['rectangle'],
        defaultUpdateOptions: {
            enableRotation: false,
            toggleToolOnClick: false
        visibleElements: {
            selectionTools: {
              "lasso-selection": false,
              "rectangle-selection": false,
            undoRedoMenu: false
    view.ui.add(sketch, "top-right");
Thanks.
Tags (1)
RobertScheitlin__GISP
@GWReid
  I do this using the SketchViewModel instead of the Sketch widget.
https://developers.arcgis.com/javascript/latest/api-reference/esri-widgets-Sketch-SketchViewModel.ht...
GWReid
New Contributor II
Thanks for the hint Robert.  I've throw together some code, but I'm missing the drawing on the map part....
<html>
  <head>
    <meta charset="utf-8" />
    <meta name="viewport"
      content="initial-scale=1,maximum-scale=1,user-scalable=no" />
    <title>Sketch update validation | Sample | ArcGIS API for JavaScript 4.19</title>
    <link rel="stylesheet" href="https://js.arcgis.com/4.19/esri/themes/light/main.css" />
    <script src="https://js.arcgis.com/4.19/"></script>
    <style>
      html,
      body,
      #viewDiv {
        padding: 0;
        margin: 0;
        height: 100%;
        width: 100%;
      #instructions {
        width: 225px;
        background: #fff;
        padding: 10px;
      .esri-button {
        display: inline-block;
        width: 75px;
      .relative {
        padding: 10px;
        position: relative;
        margin: 10px;
    </style>
    <script>
      require([
        "esri/widgets/Sketch/SketchViewModel",
        "esri/Graphic",
        "esri/Map",
        "esri/views/MapView",
        "esri/layers/GraphicsLayer",
        "esri/geometry/Polygon",
        "esri/widgets/Expand"
      ], function(
        SketchViewModel,
        Graphic,
        Map,
        MapView,
        GraphicsLayer,
        Polygon,
        Expand
        let sketchViewModel,
          instructionsExpand;
        const graphicsLayer = new GraphicsLayer();
        const map = new Map({
          basemap: "streets",
          layers: [graphicsLayer]
        const view = new MapView({
          container: "viewDiv",
          map: map,
          zoom: 6,
          center: [-82, 35]
        setUpInstructions();
        view.when(function() {
           sketchViewModel = new SketchViewModel({
            view: view,
            polygonSymbol: {
              type: "simple-fill",
              color: "rgba(255,0,0, 0.8)",
              style: "solid",
              outline: {
                color: "black",
                width: 1
          sketchViewModel.on("create", function(evt) {
            graphicsLayer.add(evt.graphic);
        const drawBtn = document.getElementById("draw");
        drawBtn.addEventListener("click", function() {
          console.log("draw button");
          graphicsLayer.removeAll();
          sketchViewModel.create("polygon");
        const resetBtn = document.getElementById("reset");
        resetBtn.addEventListener("click", function() {
          console.log("reset button");
        function setUpInstructions() {
          const sampleInstructions = document.getElementById("instructions");
          instructionsExpand = new Expand({
            expandIconClass: "esri-icon-question",
            expandTooltip: "How to use this sample",
            expanded: true,
            view: view,
            content: sampleInstructions
          view.ui.add(instructionsExpand, "top-left");
          // hide the instructions expand widget when the view becomes focused
          view.watch("focused", function(newValue, oldValue, property, object) {
            if (newValue) {
              instructionsExpand.expanded = false;
    </script>
  </head>
  <body>
    <div id="viewDiv"></div>
    <div id="instructions" class="esri-widget">
      <div class="relative">
        <button class="esri-button" id="draw">Draw</button>
        <button class="esri-button" id="reset">Reset</button>
      </div>
    </div>
  </body>
</html>
@GWReid  The code you provided works fine. Once you click on the Draw button then you just click on the map to start drawing the polygon.
GWReid
New Contributor II
Oops, I was thinking "rectangle", but had "polygon" in there.  Thanks Robert.
