In version 4.8, ArcGis Tiled Map Service Layer named different?
1410
07-18-2018 12:46 PM
BulbulMajumder1
New Contributor III
In version 4.8, ArcGis Tiled Map Service Layer named different ? I can find this till version 3.25 .
I am checking in this page
Overview | API Reference | ArcGIS API for JavaScript 4.8
KenBuja
MVP Esteemed Contributor
If you have questions on what items are in 4.x as compared to 3.x, take a look at Functionality matrix | ArcGIS API for JavaScript 4.8
The ArcGISTiledMapServiceLayer class is now TileLayer
KenBuja
BulbulMajumder1
New Contributor III
Thank you Ken Buja ....Does Tile Layer work in Calcite Bootstrap too ?
KenBuja
Yes it does.
Don't forget to click the "Mark Correct" on the post that answered your question.
BulbulMajumder1
New Contributor III
Ken Buja‌, Thank you for your reply.
Yes it works. I have a related question as follows -
I created TileLayer class as
const fl7 = new TileLayer({
url: "***"
Then I added the TileLayer to the basemap as
var map = new Map({
basemap: app.basemap,
layers: [fl7]
I created a range-slider as
<div class="slidecontainer">
<input type="range" min="1" max="100" value="50" class="slider" id="myRange">
</div>
Now, how can I change the opacity of the TileLayer using the value obtained from slider?
Thanks again!
KenBuja
This is continued in this discussion.
Please mark the question as answered.
