Hi, I can easily identify a feature on layer by using onClick and Identifytask. However I would like to identify a feature of specific layers in a map service by hovering over instead of clicking. I tried using a QueryTask but I'm not really querying the layer (I don't have a where). Which method is the best to use?
Check out this sample: Feature Layer - display results as an InfoWindow onHover
Essentially you need to respond to the mouse-over and mouse-out events for each layer to apply the hover info. The sample shows how this is done.
Thank you, it's not quite working for me with the map service I am using. How do you paste javascript into a reply?
To paste a code block click on the 'Use advanced editor' at the top-right of the reply area then you can paste your code, select it then pick Javascript from the Syntax Highlighting options:
I took the code from example altered to use my map service, I am missing something because I can't get mouse move to fire.
var map, dialog; "esri/map", "esri/layers/FeatureLayer", "esri/symbols/SimpleFillSymbol", "esri/symbols/SimpleLineSymbol", "esri/renderers/SimpleRenderer", "esri/graphic", "esri/lang", "esri/Color", "dojo/number", "dojo/dom-style", "dijit/TooltipDialog", "dijit/popup", "dojo/domReady!" function ( new Map("mapDiv", { "streets", false var southCarolinaCounties = new FeatureLayer("http://gisappserv3/ArcGIS/rest/services/Engineering/MaintenancePoints/MapServer", { "District"] // southCarolinaCounties.setDefinitionExpression("STATE_NAME = 'Washington'"); var symbol = new SimpleFillSymbol( new SimpleLineSymbol( new Color([255, 255, 255, 0.35]), new Color([125, 125, 125, 0.35]) new SimpleRenderer(symbol)); new TooltipDialog({ "tooltipDialog", "position: absolute; width: 250px; font: normal normal normal 10pt Helvetica;z-index:100" var highlightSymbol = new SimpleFillSymbol( new SimpleLineSymbol( new Color([255, 0, 0]), 3 new Color([125, 125, 125, 0.35]) //close the dialog when the mouse leaves the highlight graphic "load", function () { "mouse-out", closeDialog); //listen for when the onMouseOver event fires on the countiesGraphicsLayer //when fired, create a new graphic with the geometry from the event.graphic and add it to the maps graphics layer "mouse-over", function (evt) { 'here'); var t = "<b>${District}</b>"; var content = esriLang.substitute(evt.graphic.attributes, t); var highlightGraphic = new Graphic(evt.graphic.geometry, highlightSymbol); "opacity", 0.85); function closeDialog() {
Also...I have different layers in my map service, and I am trying to hover over a point.
Also are you sure that this is the right url?
It wont open
Yes I'm sure it is correct. Not sure if there is security on it?
It looks like this works on your internal network because you are accessing just by the server name and not by a regular domain name. I would make sure DNS is set-up and your services are forward-facing from outside of your network.
