How to use view.goTo?
9282
9
11-07-2018 01:37 AM
ShakilChoudhury
New Contributor III
I have an x, y, spatialReference and zoom value that I need the map to go to. My map uses a custom basemap (same as the given spatial reference) and the view uses an extent value like so:
var view = new MapView({
container: "viewDiv",
map: map,
extent:new Extent ({"xmin": 554418, "ymin": 166279, "xmax": 584505, "ymax": 144457, "spatialReference":{"wkid": 27700}})
I can't get view.goTo to work no matter what I do.
Tags (3)
RobertScheitlin__GISP
Shakil,
  Can you provide a sample?
ShakilChoudhury
New Contributor III
var ex = new Extent({
center:{
x:564460.8649987298,
y:139625.260181187
view.goTo(ex);
ShakilChoudhury
New Contributor III
Managed to get it working:
var geo = view.center;
geo.x = x;
geo.y = y;
view.goTo({
geometry:geo,
zoom:zoom
TravisBock2
New Contributor II
Worked for me as well.  I have run into this a couple of times now.  I think the documentation or api needs to be fixed. Documentation reads like the original should of worked and then {target: someGeometry} should work. Maybe I'm reading it wrong but I don't see any mention of using the geometry attribute for target.  Am I reading this wrong Esri?
Travis,
   No you are not reading anything wrong. When an Object is passed to the goTo method then the Object should have a property of target that points to a Number[]|Geometry|Geometry[]|Graphic|Graphic[]|Viewpoint. If you are not wanting to Also pass a zoom, scale, or center property with the target then you should just pass the Number[]|Geometry|Geometry[]|Graphic|Graphic[]|Viewpoint directly to the goTo method.
GregoryBologna
Occasional Contributor II
Is zoom required if you're requesting the map to be at full extent?
I'm not able to move to full extent. If I add zoom, the map just zooms.
   var featureLayer = map.layers.getItemAt(1);
        view.goTo({
          target: featureLayer.fullExtent,
          zoom: 11
        }, ZoomOptions);
Using it like this does nothing
         view.goTo(featureLayer.fullExtent);
Gregory,
    According to the API docs view.goTo(featureLayer.fullExtent); should work.
hoogw
New Contributor III
my working code:
     if you want to zoom to feature layer extend, use below function
function zoomToLayerExtent(layer)
if you want to zoom to lat, long, use below function
function zoomToLatLong(__lat, __long, __zoom){
var _url = "https://maps.lacity.org/arcgis/rest/services/Mapping/NavigateLA/MapServer/1"
var featureLayer = new FeatureLayer({
                                url: _url
map.add(featureLayer);
featureLayer.when(function() {
zoomToLayerExtent(featureLayer);
zoomToRealLocation(featureLayer)
function zoomToLayerExtent(layer) {
         return layer.queryExtent().then(function(response) {
           view.goTo(response.extent);
// bug fix https://community.esri.com/thread/224073-how-to-use-viewgoto
// https://developers.arcgis.com/javascript/latest/api-reference/esri-views-MapView.html#goTo
var esri_point = new Point({
latitude: __lat,
longitude: __long
var esri_goto_option = {
animate: true,
duration: 200,
view.goTo({
       target: esri_point,
          zoom: __zoom
}, esri_goto_option)
.catch(function(error) {
if (error.name != "AbortError") {
console.error('zoom to real location, view goto error', error);
hoogw
New Contributor III
works with v4.12 and v4.16
