Hello,
I wasn't able to find an example how to use the SegmentDrawAction.
My goal is to edit an Graphic-Polygon to move and add vertices.
Thanks Mike Wunderlich
Hi Mike,
You should be able to use the editor widget: Editor | ArcGIS API for JavaScript 4.11
Hey David,
I would like to use my own user interface without ESRI-Widgets
Mike,
Perhaps take a look at this, shows logic on how to edit without using a widget: Edit without editor widget | ArcGIS API for JavaScript
