How to show zoom level at the bottom of the map when the user zooms in and out?
1589
07-22-2020 12:31 AM
SiyabongaKubeka
Hi All,
I have an Esri map, what I want to do with it is to show the zoom level at the bottom or anywhere in the map when the user zooms in or out. How can I do that? Below is the sample of the map that I am using.
<!DOCTYPE html>
<html>
  <head>
    <meta charset="utf-8" />
    <meta
      name="viewport"
      content="initial-scale=1,maximum-scale=1,user-scalable=no"
    <title>DEA GIS APPLICATION</title>
    <link
      rel="stylesheet"
      href="https://js.arcgis.com/4.12/esri/themes/light/main.css"
    <script src="https://js.arcgis.com/4.12/"></script>
    <style>
      html,
      body,
      #viewDiv {
        padding: 0;
        margin: 0;
        height: 100%;
        width: 100%;
    </style>
    <script>
      require([
        "esri/widgets/Sketch",
        "esri/Map",
        "esri/layers/GraphicsLayer",
        "esri/views/MapView"
      ], function(Sketch, Map, GraphicsLayer, MapView) {
        const layer = new GraphicsLayer();
        const map = new Map({
          basemap: "streets",
          layers: [layer]
        const view = new MapView({
          container: "viewDiv",
          map: map,
          zoom: 5,
          center: [90, 45]
        const sketch = new Sketch({
          layer: layer,
          view: view,
          availableCreateTools: ["point"]
        view.ui.add(sketch, "top-right");
        sketch.on('create', function(evt){
                                           console.log("X = ", evt.graphic.geometry.x);
                                           console.log("Y = ", evt.graphic.geometry.y);
    </script>
  </head>
  <body>
    <div id="viewDiv"></div>
  </body>
</html>
Kind Regards
Siyabonga Kubeka
0761040911
Egge-Jan_Pollé
MVP Regular Contributor
Hi Siyabonga Kubeka,
You may use watchUtils to capture the zoom level when the view becomes stationary, and then add this value to your map. Like this:
watchUtils.whenTrue(view, "stationary", function() {
  lon = parseInt(view.center.x); // with parseInt values are rounded to the full meter (coordinates in Web Mercator - EPSG:3857)
  lat = parseInt(view.center.y);
  zoomLevel = view.zoom;
  document.getElementById("location").innerHTML = "Map Center - Longitude: " + lon + " / Latitude: " + lat + " / Zoom level: " + zoomLevel;
HTH,
Egge-Jan
Here is the full solution:
<html>
<head>
  <meta charset="utf-8">
  <meta name="viewport" content="initial-scale=1, maximum-scale=1, user-scalable=no">
  <title>ArcGIS JavaScript Tutorials: show zoom level</title>
  <style>
    html, body, #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
    #location {
      padding: 15px;
      background: white;
      color: black;
       border: 5px solid gold;
       font-family: sans-serif;
       font-size: 1.2em;
  </style>
  <link rel="stylesheet" href="https://js.arcgis.com/4.16/esri/css/main.css">
  <script src="https://js.arcgis.com/4.16/"></script>
  <script>
    require([
      "esri/Map",
      "esri/views/MapView",
      "esri/core/watchUtils"
    ], function(Map, MapView, watchUtils) {
      var map = new Map({
        basemap: "streets"
      var view = new MapView({
        map: map,
        center: [90, 45], // longitude, latitude
        zoom: 5
      view.ui.add("location", "bottom-left");
  </script>
</head>
<body>
  <div id="location"></div>
</body>
</html>
Egge-Jan_Pollé
HTH,
Egge-Jan
<html>
<head>
  <style>
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
    #location {
      padding: 15px;
      background: white;
      color: black;
       font-size: 1.2em;
  </style>
  <script>
    require([
      "esri/Map",
      var map = new Map({
        basemap: "streets"
        map: map,
        zoom: 5
  </script>
</head>
<body>
</body>
</html>
SiyabongaKubeka
Hi Egge-Jan,
Thank you very much. Much appreciated. It works.
Kind Regards
Siyabonga Kubeka
