How to set a defintionExpression in JS
2789
6
10-18-2019 02:15 PM
HeathAnderson
Occasional Contributor II
I am struggling getting my definition expression to work with a time aware field.  I believe I have narrowed down the problem to the layer.definitionExpression.  I have successfully made a definition expression for a text field:
layer.definitionExpression = "project_type = 'SUP'"
but I have been unsuccessful in writing one for a time aware field.  Should I be using the field name {project_date} or 'time'?
timeSlider.watch("timeExtent", function() {
          // only show earthquakes happened up until the end of
          // timeSlider's current time extent.
          //defExp = layer.definitionExpression = "time = " + timeSlider.timeExtent.end.getTime();
          //defExp = layer.definitionExpression = "project_type = 'SUP'";
          //defExp = layer.definitionExpression = "time=1571202000000";
          defExp = layer.definitionExpression = "time="+1571202000000;
          defExp2 = layer.definitionExpression = "project_date="+1571202000000;
          //checks definitonExpression
          console.log(defExp);
          console.log(defExp2);
I know that the epoch time 1571202000000 exists in my dataset because I can query it in the rest end point and the query yields 2 results, however that doesn't seem directly translate to JS.  Can some one please help me.
UndralBatsukh
Hi there,
As Robert Scheitlin, GISP‌, you should use standard sql query to query dates. When you are setting FeatureLayer.definitionExpression you are making Rest API query call (search for where).  This blog talks about how to query date fields.
With all of the above said, you should not have to set the layer's definitionExpression whenever the timeSlider's timeExtent changes. You can set the TimeSlider.view property and all time-aware layers will automatically update to conform to the view's timeExtent. Please look through the TimeSlider SDK doc (see Update the view's doc section).
I have updated your app to do that and here is the link. I noticed that your service's time interval units is set to unknown. So in the test app, I am setting TimeSlider's stop.interval to one day as shown below:
const timeSlider = new TimeSlider({
  container: "timeSlider",
    playRate: 300,
    view: view,
    stops: {
      interval: {
        value: 1,
        unit: "days"
RobertScheitlin__GISP
Heath,
  I normally query dates in JS this way:
project_date = TIMESTAMP '2019-10-18 16:30:00'
HeathAnderson
Robert,
Thank you for your quick reply.  That code didn't seem to work either
defExp2 = layer.definitionExpression = "project_date = TIMESTAMP '2019-10-18 16:30:00'";
defExp2 = layer.definitionExpression = "project_date = TIMESTAMP 2019-10-18 16:30:00";
I had thought about using the TIMESTAMP earlier in my vetting process but seeing as how the database stores it in epoch as well as the timeslider querying in epoch I thought I though I would stick with it.
Either way, neither the TIMESTAMP or epoch code seems to be working with the fieldname or "time" designation
Best,
Heath
Heath,
   It seems like you are wanting to set a features time extent (ie. begin time and end time) if so then look at the layer timeinfo property:
https://developers.arcgis.com/javascript/latest/api-reference/esri-layers-FeatureLayer.html#timeInfo
HeathAnderson
Yes i have a the startField set
const layer = new FeatureLayer({
url: "https://gis.appleton.org/pubserver/rest/services/Hosted/EnvisionAppleton/FeatureServer/0",
copyright: "City of Appleton",
title: "Envision Appleton",
// set the CSVLayer's timeInfo based on the date field
timeInfo: {
startField: "project_date", // name of the date field
interval: {
// set time interval to one day
unit: "days",
value: 1
Here is a copy of my code if you want to look at it instead of me sending snippets
https://codepen.io/handerson1/pen/gOOLYMw?editors=1001
UndralBatsukh
Hi there,
    playRate: 300,
    view: view,
    stops: {
      interval: {
        value: 1,
        unit: "days"
HeathAnderson
Hi Undral,
Thank you for the detail explanation.  That cleared it up for me
Best,
Heath
