Hi All,
I need help with separation the latitude and longitude. I am drawing a polygon and getting the coordinates of each vertex of the polygon. This is what I have done to separate the coordinates but it is not working:
for (var i = 0; i < gra.geometry.rings.length; i++){
for (var p = 0; p < gra.geometry.rings.length; p++){
crmLatitude = String(gra.geometry.rings
.getLatitude());
crmLongitude = String(gra.geometry.rings
.getLongitude());
var LatLon = String(gra.geometry.rings
console.log(LatLon);
latlon = LatLon;
The error that I get when I debug I get an error that states that getLatitude() is not a function.
Please assist.
Kind Regards
Siyabonga Kubeka
Solved! Go to Solution.
OK, I was mixing 3.x and 4.x code. In 4.x there is no getLatitude function, it is now just a property of the point.
if (event.state === "complete") {
if (view.zoom >= 11) {
let gra = event.graphic.clone();
//event.graphic.layer.removeAll();
event.graphic.symbol.color = "red";
//gra.layer.add(gra);
console.log(view.zoom);
console.log("X = ", gra.geometry.centroid.x);
console.log("Y = ", gra.geometry.centroid.y);
console.log("Lat = ", event.graphic.geometry.centroid.latitude);
console.log("Long = ", event.graphic.geometry.centroid.longitude);
lat = event.graphic.geometry.centroid.latitude;
lon = event.graphic.geometry.centroid.longitude;
zoomLevel = view.zoom;
for (var i = 0; i < gra.geometry.rings.length; i++) {
for (var p = 0; p < gra.geometry.rings[i].length; p++) {
var pnt = gra.geometry.getPoint(i, p);
crmLatitude = String(pnt.latitude);
crmLongitude = String(pnt.longitude);
var LatLon = String(pnt);
console.log(crmLatitude);
console.log(crmLongitude);
latlon = LatLon;
} else {
alert("please zoom in");
event.graphic.layer.remove(event.graphic);
The new error you were getting is because you were removing the graphics with event.graphic.layer.removeAll(). this was an issue as you are asking the sketch widget to update the drawn graphic immediately yet you removed it and replaced it with a clone.
You need to use getPoint method on the polygon.
for (var p = 0; p < gra.geometry.rings[i].length; p++){
crmLatitude = String(gra.geometry.getPoint(i, p).getLatitude());
crmLongitude = String(gra.geometry.getPoint(i, p).getLongitude());
var LatLon = String(gra.geometry.rings[i][p]);
latlon = LatLon;
Hi Robert,
I did use this way but I still get the error that says getLatitude() is not a function.
Your loops are going to high.
for (var i = 0; i < gra.geometry.rings.length - 1; i++){
for (var p = 0; p < gra.geometry.rings[i].length - 1; p++){
Hi Robert,
Can you please how me with an example that is working? I have changed my loops as above, now I get this error.
Kind Regards
Siyabonga Kubeka
That is a new different error. How about we do the reverse as I am the one providing the help. You provide your code or a sample you are having trouble with.
Hi Robert,
No problem, here is my code:
<html><head>
<meta charset="utf-8">
<meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
<title>GIS Map for CRM</title>
<link href="https://js.arcgis.com/4.14/esri/themes/light/main.css" rel="stylesheet">
<script src="https://js.arcgis.com/4.14/"></script>
<style>
html,
#viewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
.esri-sketch__section.esri-sketch__tool-section:last-of-type {
display: none;
.esri-sketch__section.esri-sketch__tool-section:nth-child(2) {
border-right: none;
</style>
<script>
var lon;
var lat;
var crmLatitude;
var crmLongitude;
var latlon;
var provinces;
var municipalities;
var districts;
var wards;
var showWards = [];
var testingV = "Gautengs";
if(testingV == "Gauteng")
require(["esri/views/MapView",
"esri/WebMap",
"esri/config",
"esri/widgets/Sketch",
"esri/layers/GraphicsLayer"],
function(MapView, WebMap, esriConfig, Sketch, GraphicsLayer) {
esriConfig.portalUrl = "https://portal.environment.gov.za/portal";
var webmap = new WebMap({
portalItem: {
// autocasts as new PortalItem()
var graphicsLayer = new GraphicsLayer();
var view = new MapView({
map: webmap,
container: "viewDiv"
webmap.layers.add(graphicsLayer);
var sketch = new Sketch({
layer: graphicsLayer,
view: view,
//container: "viewDiv"
//view.ui.add(sketch, {
// position: "top-right"
// Listen to sketch widget's create event.
sketch.on("create", function(event) {
// check if the create event's state has changed to complete indicating
// the graphic create operation is completed.
// remove the graphic from the layer. Sketch adds
// the completed graphic to the layer by default.
graphicsLayer.remove(event.graphic);
// use the graphic.geometry to query features that intersect it
selectFeatures(event.graphic.geometry);
else
//window.parent.Xrm.Page.getAttribute("dea_ward").setValue("");
require([
"esri/Map",
"esri/WebMap",
"esri/layers/FeatureLayer",
"esri/tasks/QueryTask",
"esri/tasks/support/Query",
"esri/config",
function(Map, MapView, WebMap, FeatureLayer, QueryTask, Query,
const featureLayerUrl = 'https://portal.environment.gov.za/server/rest/services/Boundary/Wards/MapServer/0';
portalItem: {
map: webmap,
container: "viewDiv",
popup: null
var featureLayer = new FeatureLayer({
url: featureLayerUrl
webmap.add(featureLayer);
view: view,
availableCreateTools: ["polygon"],
creationMode: "update",
sketch.on('create', function (event) {
gra.symbol.color = "red";
gra.layer.add(gra);
console.log("X = ", gra.geometry.x);
console.log("Y = ", gra.geometry.y);
console.log("Lat = ", event.graphic.geometry.latitude);
console.log("Long = ", event.graphic.geometry.longitude);
lat = event.graphic.geometry.latitude;
lon = event.graphic.geometry.longitude;
for (var p = 0; p < gra.geometry.rings.length - 1; p++){
latlon = LatLon;
debugger;
else{
view.on('click', function(event){
var queryTask = new QueryTask({
var query = new Query();
query.geometry = view.toMap(event);
query.distance = 0;
query.units = "meters";
query.spatialRelationship = "intersects";
query.returnGeometry = true;
query.outFields = [ "PROVINCE", "DCS12_NAME", "S12_NAME", "WARD_NO" ];
queryTask.execute(query).then(function(results){
var feat = results.features[0];
provinces = feat.attributes.PROVINCE;
wards = feat.attributes.WARD_NO;
districts = feat.attributes.DCS12_NAME;
municipalities = feat.attributes.S12_NAME
showWards.push(wards);
var xwards = showWards.toString();
console.log(provinces);
console.log(wards);
console.log(districts);
console.log(municipalities);
console.log(xwards);
//Call to CRM to populate the lookup field for Province
debugger;
window.parent.Xrm.WebApi.online.retrieveMultipleRecords("dea_province", "?$select=dea_name,dea_provinceid&$filter=dea_name eq '" + provinces + "'").then(
function success(results) {
debugger;
for (var i = 0; i < results.entities.length; i++) {
var dea_name = results.entities["dea_name"];
var dea_provinceid = results.entities["dea_provinceid"];
//Populate lookup
var lookupValue = new Array();
lookupValue[0] = new Object();
lookupValue[0].id = dea_provinceid; // GUID of the lookup id
lookupValue[0].name = dea_name; // Name of the lookup
lookupValue[0].entityType = "dea_province"; //Entity Type of the lookup entity
window.parent.Xrm.Page.getAttribute("dea_province").setValue(lookupValue);
function(error) {
Xrm.Utility.alertDialog(error.message);
//Call to CRM to populate the lookup field for the Local Municipality
window.parent.Xrm.WebApi.online.retrieveMultipleRecords("dea_localmunicipality", "?$select=dea_localmunicipalityid,dea_name&$filter=dea_name eq '" + municipalities + "'").then(
var dea_localmunicipalityid = results.entities["dea_localmunicipalityid"];
//Populate lookup
lookupValue[0].id = dea_localmunicipalityid; // GUID of the lookup id
lookupValue[0].entityType = "dea_localmunicipality"; //Entity Type of the lookup entity
window.parent.Xrm.Page.getAttribute("dea_localmunicipality").setValue(lookupValue);
function(error) {
//Call to CRM to populate the lookup field for District Municipality
window.parent.Xrm.WebApi.online.retrieveMultipleRecords("dea_districtmunicipality", "?$select=dea_districtmunicipalityid,dea_name&$filter=dea_name eq '" + districts + "'").then(
var dea_districtmunicipalityid = results.entities["dea_districtmunicipalityid"];
//Populate lookup
lookupValue[0].id = dea_districtmunicipalityid; // GUID of the lookup id
lookupValue[0].entityType = "dea_districtmunicipality"; //Entity Type of the lookup entity
window.parent.Xrm.Page.getAttribute("dea_districtmunicipality").setValue(lookupValue);
function(error) {
//Populate the coordinates field
debugger;
window.parent.Xrm.Page.getAttribute("dea_latitude").setValue(latlon);
window.parent.Xrm.Page.getAttribute("dea_longitude").setValue(latlon);
window.parent.Xrm.Page.getAttribute("dea_ward").setValue(xwards);
//THE END OF CALLS TO CRM
</script>
<meta><meta></head><body style="overflow-wrap: break-word;">
<div id="viewDiv"></div>
</body></html>
latlon = LatLon;
} else {
Hi Robert,
Thank you very much for your help. It works perfectly. How do I learn this stuff?
Thank a lot again.
Kind Regards
Siyabonga
Just reading the help docs and experience.
