How to retrieve the values of a row of the Grid
4369
11
03-22-2021 05:58 AM
ShaningYu
Honored Contributor
I created FeatureTable dynamically, as below:
contx.myTable = new mv.esriModules.FeatureTable({
layer: contx.crimeFeatureLayer,
visibleElements: { selectionColumn: false },
fieldConfigs: _fieldsConfig,
container: contx.gridTbl[0] //document.getElementById("tableDiv")
The FetaureTable's data are populated in a Grid (container: contx.gridTbl[0]).  Now I click a row of the Grid.  I want to retrieve this row's value.  How can it be done?  Thanks if you can help.
3 Solutions
KenBuja
MVP Esteemed Contributor
The 'selection-change' event is fired when you click the checkbox for a row. The event.added property adds the rows selected to an array and the event.remove adds the removed rows to another array. In this example, I have a master array that contains one attribute of the current selected records for the table, adding and removing rows as they are selected or unselected.
  let filterArray: number[];
  featureTable.on('selection-change', (event) => {
    if (event.added.length > 0) filterArray.push(event.added[0].feature.attributes[valueString]);
    if (event.removed.length === 1) {
      const i = filterArray.indexOf(event.removed[0].feature.attributes[valueString]);
      filterArray.splice(i, 1);
    } else if (event.removed.length > 0) {
      filterArray = [];
    //do things with the filterArray as the selection changes
KenBuja
visibleElements: {selectionColumn: true}
KenBuja
visibleElements is a property of the FeatureTable, not a CSS element. You use that in your original post.
KenBuja
      filterArray = [];
ShaningYu
Honored Contributor
Dear Ken: Thanks for your quick response.  In my Grid, there is no "Checkbox" column.  How can the column be turned on to display by setting the css?  Thanks for your guidance!
KenBuja
KenBuja
The property defaults to true, so you can just leave it off if you aren't making changes to other visibleElements properties.
ShaningYu
Honored Contributor
I did the css like that
.esri-feature-table{
    visibleElements: {
but it shows errors.  Could you help for the style?  Thanks.
ShaningYu
Honored Contributor
when I pasted
let filterArray = number[];
on my .js file, it shows error.  What's wrong w/ this piece of code?  Thanks.
KenBuja
The code written is in TypeScript (note it used a ":" instead of "="), creating an array of numbers to hold the attribute. In regular JS, just use
let filterArray = [];
ShaningYu
Honored Contributor
Thanks.  Could you help for that piece below?  I got error if inserted in the .css.  Thanks.
    visibleElements: {
KenBuja
