How to retrieve a row's value from a FeatureTable that relates to the FeatureLayer in Clustering Points?
746
03-26-2021 04:50 AM
ShaningYu
I am using ESRI's FeatureTable widget to display clustering points on the map.  The feature records are well populated on the Grid.  What I need is that as clicking a row of the Grid, I can retrieve the values (Lat & Lon) of the row, and then possibly add a point graphic on the map.   However, due to the Clustering configuration, I can't fire the clickFunction (see the code below).
myTable = new mv.esriModules.FeatureTable({
layer: myFeatureLayer, visibleElements: { selectionColumn: true },
fieldConfigs: _fieldsConfig,
container: document.getElementById("tableDiv"),
menuConfig: {
items: [{
label: "Zoom to feature(s)",
iconClass: "esri-icon-zoom-in-magnifying-glass",
clickFunction: function (event) { //
debugger;
//zoomToSelectedFeatureTable();
//console.log("Need to build zoomToSelectedFeatureTable function");
I can only retrieve a cell's value.  Is it possible to retrieve the whole row's values?  Thanks.
04/01/2021 Refer to the code in https://developers.arcgis.com/javascript/latest/sample-code/widgets-featuretable-map/  the issue is resolved.  Thanks to the hint from KenBuja
