How to put queries in ArcGIS esri search?
414
12-15-2021 10:30 PM
altair
New Contributor III
I have my own query in search, How can i disable the default search function in ArcGIS search widget and apply mine?
this is the sample search widget in arcGIS, I want to override the search function, that the only thing that can be searched is the data in my query and it will appear just like in the picture
my current code
 const location = () => {
   const map = new Map({
        basemap: 'arcgis-light-gray',
      const view = new MapView({
        center: [123.5504, 12.3574], // Longitude, latitude
        container: mapDiv.current,
        map: map,
        zoom: 2, // Zoom level
        ui: {
          components: ["attribution"] // removes default widgets except for attribution
      var zoom = new Zoom({
        view: view,
        layout: "vertical"
     view.ui.add(zoom, "bottom-right");
      view
        .when((r) => {})
        .then(() => {
          mapDiv.current = view;
          search();
const search = () => {
      const searchWidget = new Search();
      mapDiv.current.ui.add(searchWidget, { position: "top-left", index: 2 });
JohnGrayson
You can learn about the Search Widget configuration in the doc:
https://developers.arcgis.com/javascript/latest/api-reference/esri-widgets-Search.html
Check out this sample:
https://developers.arcgis.com/javascript/latest/sample-code/widgets-search-multiplesource/
...and here's a modified version of the sample that shows it configured to just one custom source:
https://codepen.io/john-grayson/pen/GRMWVqw
altair
New Contributor III
can you provide an example?
JohnGrayson
I provided a link to the documentation, a link to an API sample, and a link to a custom codepen example.  If the links to the information and examples provided don't show what you need, then maybe a more detailed explanation of what you need would be appropriate, along with providing a codepen or similar showing the code of what you have tried so far so we can all experience your issues?
