How to properly extend the Sketch Widget.
1507
07-30-2019 12:25 PM
JustinMartinek
New Contributor II
We have need of extending the sketch widget to allow for some custom behaviors and buttons.  I followed the steps given in https://github.com/jcfranco/dev-summit-2017-customizing-widgets
We started by installing the types of both arcgis and dojo:
npm init --yes
npm install --save @types/arcgis-js-api
npm install dojo-typings --save-dev
packages.json
Set up the typscript config as such:
When I copy over the widget and compile, I get the following.
Errors:
I attempted to resolve the paths, but I can't find these references.  When I look in the project on git hub, some of these paths do not exist.  I must have something set up incorrectly.  Any help putting me #in the right direction would be wonderful.
ReneRubalcava
Are you copying the widget from https://github.com/Esri/arcgis-js-api/tree/4master/widgets ? That won't work unless you install all the same dependencies we use via installing the JSAPI via npm. They're really meant more as a guide and not to be used directly, although you could with some effort.
Check out the more recent version of that presentation here https://github.com/jcfranco/uc-2019-customizing-widgets
The idea is that you can extend the widget as shown in the presentation.
ReneRubalcava
JustinMartinek
New Contributor II
Thank you. It seemed to start out the same way as the one I was following, but the extending part was much more helpful.
