<!doctype html> <html> <head> <meta charset="utf-8"> <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" /> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/> <title></title> <link rel="stylesheet" href="http://js.arcgis.com/3.6/js/esri/css/esri.css"> <style> html, body, #map { height: 100%; width: 100%; margin: 0; padding: 0; } </style> <script src="http://js.arcgis.com/3.6/"></script> <script> var map, mil; require([ "esri/map", "esri/geometry/Extent", "esri/layers/MapImage", "esri/layers/MapImageLayer" ], function( Map, Extent, MapImage, MapImageLayer ) { map = new Map("map", { basemap: "topo", center: [-79.17, 33.76], zoom: 9 }); // create and add the layer mil = new MapImageLayer({ "id": "usgs_screen_overlay" }); map.addLayer(mil); // create and add the image var extent = new Extent({ "xmin": -8864908, "ymin": 3885443, "xmax": -8762763, "ymax": 3976997, "spatialReference": { "wkid": 102100 }}); var mi = new MapImage({ "extent": extent, "href": "http://hdds.usgs.gov/hdds2/view/overlay_file/AM01N33_269827W079_1773002011082800000000MS00" }); mil.addImage(mi); }); </script> </head> <body> <div id="map"></div> </body> </html>
for MapImageLayer, you don't have to dig into the information stored within the image manually.
the API will handle reading the information for you as long as the georeferenced image is inside the extent of the map and in the same spatial reference.
This thread is old, but still number 1 when searching google for "geotiff arcgis javscript", so i thought I'd share how I accomplished it
overlaying a geotiff into arcgis javascript is not possible with just the api. I used 2 other libraries to do it:
xlhomme/GeotiffParser.js · GitHub
The way I did it was to load the file as an ArrayBuffer
reader.readAsArrayBuffer(input.files[0]);
etc. explore the 2 libs
there are plans to georeference in 3d (x and z) an image, i good idea, to show crosS sections schemes on local scenes
