How to overlay a georefrenced image (geotiff) to the webmap?
8019
8
09-15-2013 08:15 PM
Pankajroy
Hi All,
Can anyone tell me how to overlay georefrenced images to webmap using javascript API.
Thanx,
Pankaj Roy
Pankajroy
I belive it can be done using ESRI.Layers.MapImageLayer. Can anyone suggest how to retrieve the georef info such as extent and spatial refrence?
Rgds,
Pankaj Roy
JohnGravois
for MapImageLayer, you don't have to dig into the information stored within the image manually.
the API will handle reading the information for you as long as the georeferenced image is inside the extent of the map and in the same spatial reference.
derekswingley1
Here's a simple example using MapImageLayer:
<!doctype html>
<html>
  <head>
    <meta charset="utf-8">
    <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" />
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
    <title></title>
    <link rel="stylesheet" href="http://js.arcgis.com/3.6/js/esri/css/esri.css">
    <style>
      html, body, #map { height: 100%; width: 100%; margin: 0; padding: 0; }
    </style>
    <script src="http://js.arcgis.com/3.6/"></script>
    <script>
      var map, mil;
      require([
        "esri/map", "esri/geometry/Extent",
        "esri/layers/MapImage", "esri/layers/MapImageLayer"
      ], function(
        Map, Extent,
        MapImage, MapImageLayer
        map = new Map("map", {
          basemap: "topo",
          center: [-79.17, 33.76],
          zoom: 9
        // create and add the layer
        mil = new MapImageLayer({ "id": "usgs_screen_overlay" });
        map.addLayer(mil);
        // create and add the image
        var extent = new Extent({ "xmin": -8864908, "ymin": 3885443, "xmax": -8762763, "ymax": 3976997, "spatialReference": { "wkid": 102100 }});
        var mi = new MapImage({
          "extent": extent,
          "href": "http://hdds.usgs.gov/hdds2/view/overlay_file/AM01N33_269827W079_1773002011082800000000MS00"
        mil.addImage(mi);
    </script>
  </head>
  <body>
    <div id="map"></div>
  </body>
</html>
http://jsbin.com/uNeXera/1/
Pankajroy
Thanks for the reply, will check it out.
Thanx,
Pankaj Roy
BetsySchenck-Gardner
I don't believe you can overlay a tif image onto the map. Your map image has to be in gif, jpeg, bmp, or png format according to the MapImage documentation.
aa20
This thread is old, but still number 1 when searching google for "geotiff arcgis javscript", so i thought I'd share how I accomplished it
overlaying a geotiff into arcgis javascript is not possible with just the api. I used 2 other libraries to do it:
seikichi/tiff.js · GitHub
xlhomme/GeotiffParser.js · GitHub
The way I did it was to load the file as an ArrayBuffer
  reader.readAsArrayBuffer(input.files[0]);
aa20
etc. explore the 2 libs
ArmandoFreites16
there are plans to georeference in 3d (x and z) an image, i good idea, to show crosS sections schemes on local scenes
