How to modify Conversion Options in the Coordinate Conversion Widget?
2138
8
10-24-2018 07:56 AM
RichardHughes2
Occasional Contributor III
const ccWidget = new CoordinateConversion({
 view: this.view,
 container: element
 const filt_formats = ccWidget.viewModel.formats.filter((format) => {
 if (["basemap", "dms"].indexOf(format.name) === -1) {
 return true;
 } else {
 return false;
 filt_formats.forEach((format) => {
 ccWidget.formats.remove(format);
 ccWidget.render();‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
In the above code I am trying to limit the conversion options in the Coordinate Conversion widget.  The formats are limited, and the conversions when the widget loads is a Collection of 1.  The issues is that the <Select> element in the widget still contains all of the original format options.  Updating the viewModel should trigger the Widget to render() so I have tried updating that as well, and I am calling render() to be sure.
ccWidget.viewModel.formats.remove(format);
The error I get in the browser states, "Uncaught Error: select had a option child removed, but there is now more than one. You must add unique key properties to make them distinguishable."
<select aria-controls="ccNode__list-item-0" aria-label="Select format" class="esri-select esri-coordinate-conversion__select-row" title="Select format"><option aria-label="xy" title="xy">XY</option><option aria-label="basemap" value="basemap">BASEMAP</option><option aria-label="dms" value="dms">DMS</option><option aria-label="dms" value="dms">DMS</option><option aria-label="mgrs" value="mgrs">MGRS</option><option aria-label="usng" value="usng">USNG</option><option aria-label="utm" value="utm">UTM</option></select>
I don't think I should modify the domNode, but the widget render() should update it.  What am I missing here?
Tags (1)
Flookfinders
New Contributor II
After a lot of playing around I finally managed to get this to work using the reactiveUtils in v4.24 by using the following code:
reactiveUtils
  .whenOnce(() => ccWidget.formats.length > 0)
  .then(() => {
    let filteredFormats =
      ccWidget.formats.items.filter(
        (f) => f.name === "basemap" || f.name === "xy"
    filteredFormats[
      filteredFormats.findIndex((f) => f.name === "basemap")
    ].label = "BNG";
    filteredFormats[
      filteredFormats.findIndex((f) => f.name === "xy")
    ].label = "Long/Lat";
    ccWidget.formats.items = filteredFormats;
reactiveUtils
  .whenOnce(() => ccWidget.conversions)
  .then(() => {
    ccWidget.conversions.removeAll();
    const f = ccWidget.formats.items.find(
    ccWidget.conversions.add(
      new Conversion({ format: f })
JanupriyaSankar
This will work
var ccWidget = new CoordinateConversion();
var format = ccWidget.formats.filter(function (format) {
return format.name === "xy";
var coordinateConversionWidget = new CoordinateConversion({
view: view,
formats: format,
multipleConversions: false
rogenjh
New Contributor III
Has anyone gotten this to work? It does not for me.
Noah-Sager
Hi @rogenjh, this is a good question. It looks like we can use watchUtils to wait until the formats are ready, since formats now starts empty.
Code snippet with just BASEMAP and XY:
watchUtils.whenOnce(ccWidget, "formats.length", () => {
  ccWidget.formats = ccWidget.formats.filter(f => {
    return f.name === "xy" || f.name === "basemap"
test-app with just BASEMAP and XY:
https://codepen.io/noash/pen/XWMmmza?editors=1000
rogenjh
New Contributor III
Wow. That worked perfect for me. What was screwing up the initial solution was that formats begin empty now, I suppose. Thanks for your help!
nadja_swiss_parks
Hi @Noah-Sager
Thanks for this solution. This worked for me as long as I only used the default formats.
As fas as I see in this thread, the names of the default format cannot be changed. Unfortunately, I need names which are easy to understand. Thus I added my own format, according to this sample code.
My own format works and can bee added and removed to the collection of formats:
coordinateConversionWidget.formats.add(crs2056);
But I cannot remove the default formats using this command:
coordinateConversionWidget.formats.remove(xy);
Nor can I filter the formatsusing above solution. How can I display ONLY my custom format? (later on, I'll add a second one (epsg:3857)
Here you find my test: https://codepen.io/nwp_nadja_bernhard/pen/OJvWeMP?editors=0010
If you comment line 193, it works fine. But as soon as the custom format is added, it doesnot work any more.
Flookfinders
New Contributor II
Hi @Noah-Sager I was using the above code, which was working fine, but when I try and change it to use the newer reactiveUtils rather than watchUtils this no longer works.  How do you achieve the same result using the new reactiveUtils?
Flookfinders
New Contributor II
reactiveUtils
  .then(() => {
    filteredFormats[
    ].label = "BNG";
    filteredFormats[
reactiveUtils
  .then(() => {
Noah-Sager
Glad to hear it, and you're quite welcome. Feel free to mark the solution so other users know the question has been answered.
