How to make single selection on a FeatureTable
2668
6
05-14-2021 11:24 AM
ShaningYu
Refer to https://developers.arcgis.com/javascript/latest/sample-code/widgets-featuretable-map/, I loaded ESRI's FeatureTable widge into my App.  Is it possible to make single record selection rather than multiple records selection?  I mean that if clicking a record, the previous selected record should be checked off.  Thanks.
UndralBatsukh
UndralBatsukh
Hi there,
Yes it is possible. Just call FeatureTable.clearSelection() method right before you call FeatureTable.selectRows() method.
I modified an SDK sample for this.
Hope this helps,
-Undral
ShaningYu
Undral:  Thanks for your response.  Actually, I did have used the code
myTable.on('selection-change', (event) => {
myTable.clearSelection();
event.added.forEach(function (item) { ...
It does clear the selection.  However, the new-clicked row's check-on also becomes off.  I wonder if there is away to keep the new-clicked row checked-on.
UndralBatsukh
Hi there,
Please take a look at the test app provided above. You must clear the selection right before you call FeatureTable.selectRows() method not in response to the event.
In the test app this is how the clearSelection is called.
 featureTable.clearSelection();
 candidate && featureTable.selectRows(candidate.graphic);
ShaningYu
Thanks for your response.  After adding
got error   candidate  not defined.  Could you guide me how to define the variable?  Thanks.
UndralBatsukh
It is in the app I provided.  Please take a look at the app and modify it to meet your needs. https://codepen.io/U_B_U/pen/rNyeRPL?editors=100
ShaningYu
Your approach is right.  Since my code is different somehow, I can't use yours directly till I revise my code somehow.  However, I will accept yours as the solution.  Thanks a lot.
