How to make material opacity and transparent in ExternalRenderer with three.js?
7314
10-21-2019 09:07 PM
zhiminzhang
New Contributor II
Hello, I am doing some webgl extensions with three.js following the ExternalRenderer sample,  I have created a CustomRenderer like this:
public setup(context: __esri.RenderContext): void {
    // Setup webgl renderer
    this.renderer = new WebGLRenderer({
        context: context.gl,
        alpha: true,
        antialias: true
    this.renderer.autoClear = false;
    // this.renderer.setPixelRatio(window.devicePixelRatio);
    this.renderer.setViewport(0, 0, this.view.width, this.view.height);
    this.scene = new Scene();
    this.camera = new PerspectiveCamera();
Then load a texture from a url, and add it to scene, the code looks like this:
const extent = this.properties.extent;
const elevation = this.properties.elevation;
const unit = Math.PI / 180.0 * (EarthRadius + elevation);
const width = (extent.xmax - extent.xmin) * unit;
const height = (extent.ymax - extent.ymin) * unit;
const segs = 36;
const geometry = new PlaneBufferGeometry(width, height, segs, segs);
const textureLoader = new TextureLoader();
const texture = textureLoader.load(this.properties.url);
const material = new MeshBasicMaterial({
    // color: 0xffff00,
    map: texture,
    wireframe: false,
    opacity: 0.5,
    transparent: true,
    alphaTest: 0.05,
    side: DoubleSide
this.plane = new Mesh(geometry, material);
const srcCoord = [
    (extent.xmin + extent.xmax) / 2,
    (extent.ymin + extent.ymax) / 2,
    elevation
const destCoord = [0, 0, 0];
externalRenderers.toRenderCoordinates(
    this.view,
    srcCoord,
    0,
    SpatialReference.WGS84,
    destCoord,
    0,
const transform = new Matrix4();
transform.fromArray(
    externalRenderers.renderCoordinateTransformAt(
        this.view,
        srcCoord,
        new Float32Array(16)
transform.decompose(
    this.plane.position,
    this.plane.quaternion,
    this.plane.scale
this.scene.add(this.plane);
I have set transparent to true, and opacity to 0.5 , but the texture loaded looks not transparent, but it it looks transparent in three.js.
So, how to make texture loaded transparent in external renderer?
Tags (1)
zhiminzhang
New Contributor II
Finally I get the magic, enable alpha blend before render, it is disabled by arcgis js api
protected beforeRender(context: __esri.RenderContext): void {
    super.beforeRender(context);
    const opacity = this.props.opacity;
    if (this.isTransparent()) {
        const gl = context.gl;
        gl.enable(gl.BLEND);
        gl.blendFunc(gl.NONE, gl.ONE_MINUS_SRC_ALPHA);
zhiminzhang
New Contributor II
I have built a demo with three.js on stackbliz , with pure three.js, make things transparent is easy, just set the transparent property  MeshBasicMaterial to true , and set opacity property to less then 1.0 , the result looks like this:
But set the transparent and opaticy properties does not work in an ExternalRenderer of SceneView, can not make things transparent and opaque.
zhiminzhang
New Contributor II
