How to make graphic not moving when zoom the map?
888
6
08-09-2021 08:40 PM
howard
New Contributor II
I have a question, I use SketchViewModel to draw the shape on map, I want to keep the shape located in center (not moving) when the zoom in/out the map; how can I implement it?
Thanks in advance.
LefterisKoumis
Occasional Contributor III
Use the center of the screen as the coordinates of your graphic.
var x = window.innerWidth / 2;
var y = window.innerHeight / 2;
howard
New Contributor II
Thanks LefterisKoumis.
If the shape is not in center, how make the shape looks like keeping statis position and size?
CourtneyMenikheim
This question is answered on this thread: https://community.esri.com/t5/arcgis-api-for-javascript-questions/how-to-make-graphic-not-moving-whe...
(In case anyone else stumbles along looking for an answer)
Courtney Menikheim | Application Developer | @thecmenikheim
howard
New Contributor II
Hi CourtneyMenikheim
Your mentioned thread is keeping the shape not moved when moving the map; but how to keep the shape not scale and move (size and position looks like unchange in screen) when zooming the map; adjust the coordinates of shape seems that cannot get the desired effect.
Could you give some helps, thanks!
Thanks.
CourtneyMenikheim
To clarify, you want the shape:
- to be on the map
- to stay on the screen in the same spot, even as the user pans the map
- to stay the same size, even as the user zooms in and out
Is that correct?
howard
New Contributor II
Yes, that is correct!
Thanks!
