How to load chinese language basemap?
1116
08-05-2019 01:39 AM
Eriche
How to load  basemap with language chinese to SceneView, like https://www.arcgis.com/home/webscene/viewer.html ?
KellyHutchins
Esri Frequent Contributor
You can find a gallery of the available base maps in this blog post:
https://www.esri.com/arcgis-blog/products/arcgis-online/announcements/whats-new-in-esri-vector-basem...
Looks like they have base maps for Chinese (Hong Kong), Chinese (Taiwan) and Modern Chinese. In the snippet below I use the base map id for one of the Chinese base maps and set it as the map's base map.
      var id = "7507c43a3cee4aa282453a11e9be62fc";
        var map = new Map({
          basemap: new Basemap({
            portalItem:{
          ground: "world-elevation"
BenElan
Hi Eric,
You can use an Esri vector basemap found here:
There are 3 choices for Chinese (Hong Kong, Taiwan, and Modern)
KellyHutchins
        var map = new Map({
            portalItem:{
Eriche
Thank you very much! It's solved!
