How to know when a VectorTileLayer is finished rendering? (ArcGIS API for JavaScript)
4711
7
01-20-2020 02:34 PM
DvirShimol
I would like to use VectorTileLayer
But I can't find any event that fires when layer rendering is done.
'load' event fires:
Fires after layer properties for the layer are successfully populated.
So basically load event it's very quick (it's a small json) but it's not what I am looking for.
'update-end' not fires.
maybe there is other method to determine if VectorTileLayer is finish to render.
Br,
Dvir.
AshokVanam1
New Contributor III
Try the event "update" which is part of inherited class "Layer".
Also try other events "update-end" and "update-start" Layer | API Reference | ArcGIS API for JavaScript 3.31
DvirShimol
I tried 'update' and 'update-end' unfortunately it's not working.
example code can see here:
https://codepen.io/Dvirus/pen/wvBRgjg?editors=1001
Br,
Dvir.
UndralBatsukh
Hi there,
The `update-start` and `update-end` events are not firing for the VectorTileLayer. We created an issue for this and I will give you an update once it is fixed. In meantime, please try using Map.update-end event.
-Undral
DvirShimol
Hi ,
Thanks for create issue for this and I will glad to be updated once it is fixed.
unfortunately even Map.update-endevent not fired.
I have update the codepen
https://codepen.io/Dvirus/pen/wvBRgjg?editors=1000
Br,
Dvir.
KenBuja
MVP Esteemed Contributor
If you add a basemap to the map constructor, the map's "update-start" and "update-end" events will fire.
var map = new Map("map", {
  center: [2.3508, 48.8567], // longitude, latitude
  zoom: 7,
  basemap: "topo"
DvirShimol
Hi there,
basemap "topo" It is not a vector map
I need to use "topo-vector" which it's a vector map.
The problem is that I need to use vector map but I can't know when it's finish to redraw/render.
None of those vector maps not fires 'update-end':
   dark-gray-vector,
   gray-vector,
   streets-vector,
   topo-vector,
   streets-night-vector,
   streets-relief-vector,
   streets-navigation-vector
I tried also to add the layer to map. still the same.
Thanks toUndral Batsukh  for opening issue for this, and I hope that issue will be fixed soon.
Br,
Dvir.
UndralBatsukh
Hi there,
I should have checked for the map update events when the basemap is vector tile layer. I confirmed that map update events are indeed not firing for vectortilelayer basemaps. This issue will be fixed at our next release (3.32).
Thank you for reporting this issue,
-Undral
