How to hide unwanted tools in editor toolbar widget?
3745
15
11-22-2016 09:11 AM
KushendraShah1
New Contributor III
I need to customize the editor toolbar widget by hiding the list of unwanted tools for me in editor toolbar widget. Is there way I could get this done deactivating and hiding such tools in javascript or css?. It seems like those tools came as default in editor widget. However I was able to remove the display of some tools/buttons in dropdown like delete, AddToSelection, NewSelection, Attributes, ClearSelection. Here is the remaining buttons/tools that I wanted to hide or remove from the widget for my application and only keep undo/redo button. Appreciate for any help. Thanks
RobertScheitlin__GISP
Kushendra,
   Sure here is a sample that shows how:
<!DOCTYPE html>
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
    <title>Edit rivers and waterbodies</title>
    <link rel="stylesheet" href="https://js.arcgis.com/3.18/dijit/themes/claro/claro.css">
    <link rel="stylesheet" href="https://js.arcgis.com/3.18/esri/css/esri.css">
    <style>
      html,body{height:100%;width:100%;margin:0;overflow:hidden;}
      #map{
        padding:0;
      #header{
        font-size: 1.1em;
        font-family: sans-serif;
        padding-left: 1em;
        padding-top:4px;
        color:#660000;
      .templatePicker {
        border: none;
      .dj_ie .infowindow .window .top .right .user .content { position: relative; }
      .dj_ie .simpleInfoWindow .content { position: relative; }
    </style>
    <script src="https://js.arcgis.com/3.18/"></script>
    <script>
      var map;
      require([
        "esri/map",
        "esri/tasks/GeometryService",
        "esri/layers/ArcGISTiledMapServiceLayer",
        "esri/layers/FeatureLayer",
        "esri/Color",
        "esri/symbols/SimpleMarkerSymbol",
        "esri/symbols/SimpleLineSymbol",
        "esri/dijit/editing/Editor",
        "esri/dijit/editing/TemplatePicker",
        "esri/config",
        "dojo/i18n!esri/nls/jsapi",
        "dojo/_base/array", "dojo/parser", "dojo/keys", "dojo/query", "dojo/dom-style",
        "dijit/layout/BorderContainer", "dijit/layout/ContentPane",
        "dojo/domReady!"
      ], function(
        Map, GeometryService,
        ArcGISTiledMapServiceLayer, FeatureLayer,
        Color, SimpleMarkerSymbol, SimpleLineSymbol,
        Editor, TemplatePicker,
        esriConfig, jsapiBundle,
        arrayUtils, parser, keys, query, domStyle
        parser.parse();
        // snapping is enabled for this sample - change the tooltip to reflect this
        jsapiBundle.toolbars.draw.start = jsapiBundle.toolbars.draw.start +  "<br>Press <b>ALT</b> to enable snapping";
        // refer to "Using the Proxy Page" for more information:  https://developers.arcgis.com/javascript/3/jshelp/ags_proxy.html
        esriConfig.defaults.io.proxyUrl = "/proxy/";
        //This service is for development and testing purposes only. We recommend that you create your own geometry service for use within your applications.
        esriConfig.defaults.geometryService = new GeometryService("https://utility.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer");
        map = new Map("map", {
          basemap: "satellite",
          center: [-96.541, 38.351],
          zoom: 14,
          slider: false
        map.on("layers-add-result", initEditor);
        //add boundaries and place names
        var labels = new ArcGISTiledMapServiceLayer("https://server.arcgisonline.com/ArcGIS/rest/services/Reference/World_Boundaries_and_Places/MapServer");
        map.addLayer(labels);
        var responsePoints = new FeatureLayer("https://sampleserver6.arcgisonline.com/arcgis/rest/services/Wildfire/FeatureServer/0", {
          mode: FeatureLayer.MODE_ONDEMAND,
          outFields: ['*']
        var responsePolys = new FeatureLayer("https://sampleserver6.arcgisonline.com/arcgis/rest/services/Wildfire/FeatureServer/2", {
          outFields: ['*']
        map.addLayers([responsePolys, responsePoints]);
        function initEditor(evt) {
          var templateLayers = arrayUtils.map(evt.layers, function(result){
            return result.layer;
          var templatePicker = new TemplatePicker({
            featureLayers: templateLayers,
            grouping: true,
            rows: "auto",
            columns: 3
          }, "templateDiv");
          templatePicker.startup();
          var layers = arrayUtils.map(evt.layers, function(result) {
            return { featureLayer: result.layer };
          var settings = {
            map: map,
            templatePicker: templatePicker,
            layerInfos: layers,
            toolbarVisible: true,
            createOptions: {
              polylineDrawTools:[ Editor.CREATE_TOOL_FREEHAND_POLYLINE ],
              polygonDrawTools: [ Editor.CREATE_TOOL_FREEHAND_POLYGON,
                Editor.CREATE_TOOL_CIRCLE,
                Editor.CREATE_TOOL_TRIANGLE,
                Editor.CREATE_TOOL_RECTANGLE
            toolbarOptions: {
              reshapeVisible: false
          var params = { settings: settings };
          var myEditor = new Editor(params, 'editorDiv');
          //define snapping options
          var symbol = new SimpleMarkerSymbol(
            SimpleMarkerSymbol.STYLE_CROSS,
            15,
            new SimpleLineSymbol(
              SimpleLineSymbol.STYLE_SOLID,
              new Color([255, 0, 0, 0.5]),
            null
          map.enableSnapping({
            snapPointSymbol: symbol,
            tolerance: 20,
            snapKey: keys.ALT
          myEditor.startup();
          query(".dijit.dijitReset.dijitInline.dijitLeft.dijitComboButton", myEditor.domNode).forEach(function(node){
            domStyle.set(node, "display", "none");
    </script>
  </head>
  <body class="claro">
    <div id="main" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline'" style="height:width:100%;height:100%;">
      <div data-dojo-type="dijit/layout/ContentPane" id="header" data-dojo-props="region:'top'">
        Edit Hydrography
      </div>
      <div data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'left'" style="width: 300px;overflow:hidden;">
        <div id="templateDiv"></div>
        <div id="editorDiv"></div>
      </div>
      <div data-dojo-type="dijit/layout/ContentPane" id="map" data-dojo-props="region:'center'"></div>
    </div>
  </body>
</html>
Kushendra,
<!DOCTYPE html>
<html>
  <head>
    <style>
      #map{
        padding:0;
      #header{
        font-size: 1.1em;
        padding-left: 1em;
        padding-top:4px;
        color:#660000;
      .templatePicker {
        border: none;
    </style>
    <script>
      var map;
      require([
        "esri/map",
        "esri/Color",
        "esri/config",
        "dojo/domReady!"
      ], function(
        parser.parse();
          zoom: 14,
          slider: false
          outFields: ['*']
          outFields: ['*']
            grouping: true,
            rows: "auto",
            columns: 3
          }, "templateDiv");
          var settings = {
            map: map,
            layerInfos: layers,
            createOptions: {
            toolbarOptions: {
            15,
            null
            tolerance: 20,
            snapKey: keys.ALT
          myEditor.startup();
    </script>
  </head>
        Edit Hydrography
      </div>
      </div>
    </div>
  </body>
</html>
KushendraShah1
New Contributor III
Thanks for the sending the sample Robert. It works great with the simple toolbar sample. When I tried to put on my template which is using default editing widget,  I still see the toolbar visible. I am using editor widget without having  template picker and I don't know if it is causing an issue. All I embed was this piece of code including the module ( "dojo/_base/array",
"dojo/parser",
"dojo/keys",
"dojo/query",
"dojo/dom-style")  : query(".dijit.dijitReset.dijitInline.dijitLeft.dijitComboButton", myEditor.domNode).forEach(function(node){
I tried using this code on esri default editor widget sample ArcGIS API for JavaScript Sandbox ; it seems it is not working.
Kushendra,
  I am confused as that sample does not even show the toolbar.
KushendraShah1
New Contributor III
Robert, I activated the toolbar inside the settings variable and checked to see if works since I am using the default editor widget sample for my template.
var settings = {
map: map,
layerInfos: featureLayerInfos,
toolbarOptions: {
It displays the toolbar and when I tried using modules and put the snippet you sent in the sample doesn't work for this template (default editor widget). I don't know the issue behind since both the editor widget template and simple editor toolbar are similar to me as I am fairly new to the arcgis javascript world
Kushendra,
  OK you must of had something off in you code then. Here is a working example for the editor widget:
<!DOCTYPE html>
<html>
  <head>
    <title>Default Editor</title>
    <style>
      html, body {
        height: 100%;
        width: 100%;
        margin: 0;
      body {
        background-color: #fff;
        overflow: hidden;
        font-family: Helvetica, san-serif;
      #templatePickerPane {
        width: 225px;
        overflow: hidden;
      #panelHeader {
        background-color: #92A661;
        border-bottom: solid 1px #92A860;
        color: #FFF;
        font-size: 18px;
        height: 24px;
        line-height: 22px;
        margin: 0;
        overflow: hidden;
        padding: 10px 10px 10px 10px;
      #map {
        margin-right: 5px;
        padding: 0;
      .esriEditor .templatePicker {
        padding-bottom: 5px;
        padding-top: 5px;
        height: 500px;
        border-radius: 0px 0px 4px 4px;
        border: solid 1px #92A661;
      .dj_ie .infowindow .window .top .right .user .content, .dj_ie .simpleInfoWindow .content {
        position: relative;
    </style>
    <script>
      var map;
      require([
        "esri/config",
        "esri/map",
        "esri/SnappingManager",
        "esri/toolbars/draw",
        "dojo/keys",
        "dojo/parser",
        "dojo/_base/array",
        "dojo/query",
        "dojo/dom-style",
        "dojo/domReady!"
      ], function (
        esriConfig, Map, SnappingManager, Editor, FeatureLayer, GeometryService,
        Draw, keys, parser, arrayUtils, i18n, query, domStyle
        parser.parse();
        //snapping is enabled for this sample - change the tooltip to reflect this
        i18n.toolbars.draw.start += "<br/>Press <b>CTRL</b> to enable snapping";
        i18n.toolbars.draw.addPoint += "<br/>Press <b>CTRL</b> to enable snapping";
        //This sample requires a proxy page to handle communications with the ArcGIS Server services. You will need to
        //replace the url below with the location of a proxy on your machine. See the 'Using the proxy page' help topic
        //for details on setting up a proxy page.
          basemap: "topo",
          center: [-77.036, 38.891],
          zoom: 16
        map.on("layers-add-result", initEditing);
        var operationsPointLayer = new FeatureLayer("https://services5.arcgis.com/lVkj5PBOw7tRmIPU/arcgis/rest/services/HSEC/FeatureServer/0", {
          outFields: ["*"]
        var operationsLineLayer = new FeatureLayer("https://services5.arcgis.com/lVkj5PBOw7tRmIPU/arcgis/rest/services/HSEC/FeatureServer/1",{
          outFields: ["*"]
        var operationsPolygonLayer = new FeatureLayer("https://services5.arcgis.com/lVkj5PBOw7tRmIPU/arcgis/rest/services/HSEC/FeatureServer/3", {
          outFields: ["*"]
        map.addLayers([
          operationsPointLayer, operationsPolygonLayer, operationsLineLayer
        map.infoWindow.resize(400, 300);
        function initEditing (event) {
          var featureLayerInfos = arrayUtils.map(event.layers, function (layer) {
            return {
              "featureLayer": layer.layer
          var settings = {
            map: map,
            toolbarOptions: {
          var params = {
            settings: settings
          var editorWidget = new Editor(params, 'editorDiv');
          editorWidget.startup();
          query(".dijit.dijitReset.dijitInline.dijitLeft.dijitComboButton", editorWidget.domNode).forEach(function(node){
          //snapping defaults to Cmd key in Mac & Ctrl in PC.
          //specify "snapKey" option only if you want a different key combination for snapping
          map.enableSnapping();
    </script>
  </head>
    <div id="mainWindow" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline',gutters:false" style="width:100%; height:100%;">
      <div id="map" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'">
      </div>
      <div data-dojo-type="dijit/layout/ContentPane" id="templatePickerPane" data-dojo-props="region:'left'">
        <div id="panelHeader">
          Default Editor
        </div>
        <div style="padding:10px;" id="editorDiv">
        </div>
      </div>
    </div>
  </body>
</html>
KushendraShah1
New Contributor III
Robert, I was able to hide all the tools but the separator line. Is there way I can get rid of toolbar separator?  I use css code to hide this separator line but as soon as I stop and start my editor window it continue display. Looking forward to your help.
here is the CSS:
#dijit_ToolbarSeparator_0.dijitToolbarSeparator.dijitInline {
display: none;
KellyHutchins
Esri Frequent Contributor
You can add the following javascript at line 144 of Robert's sample to hide the separator.
     query(".dijitToolbarSeparator").style("display", "none");
Alternatively if you only want undo/redo capability then you may want to turn off the editor toolbar and just add in the undo/redo capability. Here's a sample that shows how this works with graphics:
Graphics with undo redo | ArcGIS API for JavaScript 3.18
KushendraShah1
New Contributor III
Thanks for the javascript line Kelly. Appreciated.
KushendraShah1
New Contributor III
It works great Robert! There was the small error on my code.  I really appreciated your time looking into this and solving my problem. Thank you.
Happy Thanksgiving!
Kush
