How to hide a map service layer?
1484
01-15-2019 11:00 AM
ShaningYu
How to hide a map service layer?  For a map service with 2 dozens of layers, I want to hide one of them from the TOC.  Is there is an easy way to do it?  Thanks.
TimMcGee1
Occasional Contributor III
An example of this is provided in the demo code: cmv-app/viewer.js at develop · cmv/cmv-app · GitHub
ShaningYu
Tim: Thanks for your response.  I use the code:
imageParameters: buildImageParameters({ ...
but got runtime error:  JavaScript runtime error: 'buildImageParameters' is undefined
I DO use "http://js.arcgis.com/3.27compact/" as you do.  But, for an unknown reason, this api can't be loaded in index.heml's <head></head> block, or else, the page can't be loaded.  In the <head></head> block,I load several other api's (e.g. jquery and bootstrap's api).
This api has to be loaded after the dojoConfig like below, the the apge can be loaded properly.
<script type="text/javascript">
    var dojoConfig = {
        async: true,
        packages: [{
            location: location.pathname.replace(/[^\/]+$/, '') + 'js/viewer'
            location: location.pathname.replace(/[^\/]+$/, '') + 'js/config'
            location: location.pathname.replace(/[^\/]+$/, '') + 'js/gis'
</script>
<script type="text/javascript" src="http://js.arcgis.com/3.27compact/"></script>
Could you provide your advisory to solve this problem?  Thanks.
ShaningYu
I did another try by adding the function locally
function buildImageParameters (config) {
    var ip = new ImageParameters();
    for (var key in config) {
        if (config.hasOwnProperty(key)) {
            ip[key] = config[key];
    return ip;
The 'Not found' error is gone.  But with the defined
layerIds: [1,2,3,4,5],
layerOption: ImageParameters.LAYER_OPTION_EXCLUDE
the layer 0 still in the TOC.  What's wrong in my code?  Thanks.
Noah-Sager
Shaning Yu if you're using a MapImageLayer, then you can define the visibility of the sublayer (map service layer).
Doc:
Sublayer | API Reference | ArcGIS API for JavaScript 4.10
Sample:
MapImageLayer - Toggle sublayer visibility | ArcGIS API for JavaScript 4.10
ShaningYu
I got runtime error when I use API 4.1.  The problem may be the same as using 3.27 version.  This could be the problem as I load several other API's that may cause some unknown conflicts.  Thanks.
