How to get the spatialReference of a Basemap
2099
9
11-16-2017 04:41 AM
NicoleSchmidt
New Contributor III
Is there a way to get access to the spatialReference of the basemap?  This seems like it should be simple.  I should be able to create the basemap from the portalId and check the spatial reference to predict whether the load will fail.  I have tried checking baselayers, I have tried calling .load on the basemap and .load on the baselayers then checking the spatialReference.   It is still null.
Will Esri eventually handle changing spatial references of a mapview when a user chooses a basemap that is in a different spatial reference from the currently loaded mapView?
RobertScheitlin__GISP
Nicole,
   I don't know how to do it without loading the portal item. Here is my code for loading the item and checking the spatialReference:
<!DOCTYPE html>
<html>
<head>
  <meta charset="utf-8">
  <meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
  <title>Load a basic WebMap - 4.5</title>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
  </style>
  <link rel="stylesheet" href="https://js.arcgis.com/4.5/esri/css/main.css">
  <script src="https://js.arcgis.com/4.5/"></script>
  <script>
    require([
      "esri/views/MapView",
      "esri/WebMap",
      "esri/portal/PortalItem",
      "dojo/domReady!"
    ], function(
      MapView, WebMap, PortalItem
       * Creates a new WebMap instance. A WebMap must reference
       * a PortalItem ID that represents a WebMap saved to
       * arcgis.com or an on-premise portal.
       * To load a WebMap from an on-premise portal, set the portal
       * url with esriConfig.portalUrl.
      var webmap = new WebMap({
        portalItem: { // autocasts as new PortalItem()
       * Set the WebMap instance to the map property in a MapView.
      var view = new MapView({
        map: webmap,
        container: "viewDiv"
      view.then(function(){
        var item = new PortalItem({
        item.load()
        item.fetchData("json").then(function(rslt){
          console.info(rslt.spatialReference.wkid);
  </script>
</head>
<body>
  <div id="viewDiv"></div>
</body>
</html>
Nicole,
   Based on your use of mapView can we assume you are asking about JS API 4.x?
NicoleSchmidt
New Contributor III
Apologies, yes I am talking about JS API 4.x
Nicole,
  Here si a sample that shows how to get the basemaps spatialReference:
<!DOCTYPE html>
<html>
<head>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
  </style>
  <script>
    require([
      "esri/WebMap",
      "dojo/domReady!"
    ], function(
      MapView, WebMap
        map: webmap,
        console.info(webmap.basemap.baseLayers.getItemAt(0).spatialReference.wkid);
  </script>
</head>
<body>
</body>
</html>
NicoleSchmidt
New Contributor III
Thank you, but I am trying to get the spatial reference without loading it into the map.  I am trying to accurately predict whether a "swap" of the base map is going to fail due to  "layerview:spatial-reference-incompatible".
Nicole,
   What is the info you do know about the basemap that is being added? How are you adding the new basemap?
NicoleSchmidt
New Contributor III
Robert,
This is the code I am using, I really just know the portalId of the basemap.
var basemapNew = new Basemap({
  portalItem: {
myMapView.map.basemap = basemapNew; // "layerview:spatial-reference-incompatible" is logged to the console and the basemap property set fails if the new basemap is in a different SR
If I could trap that "layerview:spatial-reference-incompatible" state, I could handle the problem after setting the basemap, but I have not been able to find a way to do that.
Nicole,
<!DOCTYPE html>
<html>
<head>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
  </style>
  <script>
    require([
      "esri/WebMap",
      "dojo/domReady!"
    ], function(
        map: webmap,
        item.load()
  </script>
</head>
<body>
</body>
</html>
NicoleSchmidt
New Contributor III
Thank you Robert, that is very helpful.
Don't forget to mark this question as answered by clicking on the "Mark Correct" link on the reply that answered your question.
