How to get the name of the country name?
1401
03-26-2021 04:05 AM
SiyabongaKubeka
Hi All,
I am trying to retrieve the country name. How can I do that? Below is my code that I use to retrieve the province, district municipality, local municipality and wards:
var query = new Query();
query.geometry = view.toMap(event);
query.distance = 0;
query.units = "meters";
query.spatialRelationship = "intersects";
query.returnGeometry = true;
query.outFields = [ "PROVINCE", "DCS12_NAME", "S12_NAME", "WARD_NO" ];
queryTask.execute(query).then(function(results){
var feat = results.features[0];
provinces = feat.attributes.PROVINCE;
wards = feat.attributes.WARD_NO;
districts = feat.attributes.DCS12_NAME;
municipalities = feat.attributes.S12_NAME
showWards.push(wards);
var xwards = showWards.toString();
console.log(provinces);
console.log(wards);
console.log(districts);
console.log(municipalities);
console.log(xwards);
I have tried using
query.outFields = [ "COUNTRY","PROVINCE", "DCS12_NAME", "S12_NAME", "WARD_NO" ];
but it is not working. Please assist
Kind Regards
Siyabonga Kubeka
JeffreyWilkerson
Occasional Contributor III
For your query, I don't see a 'where' clause or a geometry being sent.  The query needs to query by tabular values (where) or by spatial location (geometry).  Also, I don't see the queryTask being instantiated, at which point you would identify the URL (layer) that you would be querying.  Take a look at the queryTask page for more information:
QueryTask
Also, I would add an error catcher to see just what is going on, as in:
queryTask.execute(query).then(function(results) {
	console.log(results);
.catch(function (error) {
	console.error("Query Error: " + error);
SiyabongaKubeka
Hi Jeffery,
I tried putting this, but I get an error saying .catch is not a function. Please see my complete code below:
<html><head>
<meta charset="utf-8">
<meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
<title>GIS Map for CRM</title>
<link href="https://js.arcgis.com/4.14/esri/themes/light/main.css" rel="stylesheet">
<script src="https://js.arcgis.com/4.14/"></script>
<style>
html,
#viewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
.esri-sketch__section.esri-sketch__tool-section:last-of-type {
display: none;
.esri-sketch__section.esri-sketch__tool-section:nth-child(2) {
border-right: none;
</style>
<script>
var lon;
var lat;
var crmLatitude;
var crmLongitude;
var latlon;
var provinces;
var municipalities;
var districts;
var wards;
var showWards = [];
var testVariable;
require([
"esri/Map",
"esri/views/MapView",
"esri/WebMap",
"esri/layers/FeatureLayer",
"esri/tasks/QueryTask",
"esri/tasks/support/Query",
"esri/config",
"esri/widgets/Sketch",
"esri/layers/GraphicsLayer"],
function(Map, MapView, WebMap, FeatureLayer, QueryTask, Query,
esriConfig, Sketch, GraphicsLayer) {
esriConfig.portalUrl = "https://portal.environment.gov.za/portal";
const featureLayerUrl = 'https://portal.environment.gov.za/server/rest/services/Boundary/Wards/MapServer/0';
var webmap = new WebMap({
portalItem: {
var graphicsLayer = new GraphicsLayer();
var view = new MapView({
map: webmap,
container: "viewDiv",
popup: null
var featureLayer = new FeatureLayer({
url: featureLayerUrl
webmap.add(featureLayer);
webmap.layers.add(graphicsLayer);
var sketch = new Sketch({
layer: graphicsLayer,
view: view,
availableCreateTools: ["polygon"],
creationMode: "update",
view.ui.add(sketch, {
position: "top-right"
sketch.on('create', function (event) {
// check if the create event's state has changed to complete indicating
// the graphic create operation is completed.
if (event.state === "complete") {
if (view.zoom >= 11) {
let gra = event.graphic.clone();
event.graphic.layer.removeAll();
gra.symbol.color = "red";
gra.layer.add(gra);
console.log(view.zoom);
console.log("X = ", gra.geometry.x);
console.log("Y = ", gra.geometry.y);
console.log("Lat = ", event.graphic.geometry.latitude);
console.log("Long = ", event.graphic.geometry.longitude);
lat = event.graphic.geometry.latitude;
lon = event.graphic.geometry.longitude;
zoomLevel = view.zoom;
for (var i = 0; i < gra.geometry.rings.length; i++){
for (var p = 0; p < gra.geometry.rings[i].length; p++){
crmLatitude = String(gra.geometry.getPoint(i, p));
crmLongitude = String(gra.geometry.getPoint(i, p));
var LatLon = String(gra.geometry.rings[i][p]);
console.log(LatLon);
latlon = LatLon;
debugger;
else{
alert("please zoom in");
event.graphic.layer.remove(event.graphic);
view.on('click', function(event){
var queryTask = new QueryTask({
query.distance = 0;
console.log(wards);
//Call to CRM to populate the lookup field for Province
debugger;
window.parent.Xrm.WebApi.online.retrieveMultipleRecords("dea_province", "?$select=dea_name,dea_provinceid&$filter=dea_name eq '" + provinces + "'").then(
function success(results) {
debugger;
for (var i = 0; i < results.entities.length; i++) {
var dea_name = results.entities[i]["dea_name"];
var dea_provinceid = results.entities[i]["dea_provinceid"];
//Populate lookup
var lookupValue = new Array();
lookupValue[0] = new Object();
lookupValue[0].id = dea_provinceid; // GUID of the lookup id
lookupValue[0].name = dea_name; // Name of the lookup
lookupValue[0].entityType = "dea_province"; //Entity Type of the lookup entity
window.parent.Xrm.Page.getAttribute("dea_province").setValue(lookupValue);
function(error) {
Xrm.Utility.alertDialog(error.message);
//Call to CRM to populate the lookup field for the Local Municipality
window.parent.Xrm.WebApi.online.retrieveMultipleRecords("dea_localmunicipality", "?$select=dea_localmunicipalityid,dea_name&$filter=dea_name eq '" + municipalities + "'").then(
var dea_localmunicipalityid = results.entities[i]["dea_localmunicipalityid"];
//Populate lookup
lookupValue[0].id = dea_localmunicipalityid; // GUID of the lookup id
lookupValue[0].entityType = "dea_localmunicipality"; //Entity Type of the lookup entity
window.parent.Xrm.Page.getAttribute("dea_localmunicipality").setValue(lookupValue);
function(error) {
//Call to CRM to populate the lookup field for District Municipality
window.parent.Xrm.WebApi.online.retrieveMultipleRecords("dea_districtmunicipality", "?$select=dea_districtmunicipalityid,dea_name&$filter=dea_name eq '" + districts + "'").then(
var dea_districtmunicipalityid = results.entities[i]["dea_districtmunicipalityid"];
//Populate lookup
lookupValue[0].id = dea_districtmunicipalityid; // GUID of the lookup id
lookupValue[0].entityType = "dea_districtmunicipality"; //Entity Type of the lookup entity
window.parent.Xrm.Page.getAttribute("dea_districtmunicipality").setValue(lookupValue);
function(error) {
//Populate the coordinates field
debugger;
window.parent.Xrm.Page.getAttribute("dea_latitude").setValue(latlon);
window.parent.Xrm.Page.getAttribute("dea_longitude").setValue(latlon);
window.parent.Xrm.Page.getAttribute("dea_ward").setValue(xwards);
//THE END OF CALLS TO CRM
</script>
<meta><meta><meta><meta><meta><meta><meta><meta><meta><meta><meta><meta><meta><meta><meta><meta><meta><meta><meta><meta><meta><meta><meta><meta><meta><meta><meta></head>
<body style="overflow-wrap: break-word;">
<div id="viewDiv"></div>
</body></html>
Here is the error code
JeffreyWilkerson
You needed another parenthesis, or right round bracket before the catch, to finish off the 'then' function from the query.  My guess is that you added one at the end of the catch to make it compile, but that should only be 1 right parenthesis, round bracket.  Try this:
    console.log(wards);
    debugger;
            debugger;
                //Populate lookup
        function(error) {
                //Populate lookup
        function(error) {
                //Populate lookup
        function(error) {
    debugger;
SiyabongaKubeka
Hi Jeffery
Thank you very much, it now works.
