I have a function checkCoverage for a particular x,y coordinate. Which executes a QueryTask. And get the result in a call back function. A Query Object is passed to QueryTask.execute(). The coordinate to search is set in Query as below.
Is there any way to find the coordinate (Point x and y) which was set in Query object from the callback function (reportMyCoverage) result object?
This is required because I trying to run this Check Coverage Function for multiple coordinates.
checkCoverage: function (x, y ) {
var map = mySelfSearch.map;
var geographicPoint = new Point(x, y);
var projectedPoint=webMercatorUtils.geographicToWebMercator(geographicPoint);
var graphic = new Graphic(projectedPoint);
if (mySelfSearch.map.getLayer('coverageCheckGraphics_point') != undefined) { mySelfSearch.map.getLayer('coverageCheckGraphics_point').clear(); }
mySelfSearch.map.getLayer('coverageCheckGraphics_point').add(graphic);
try{
mySelfSearch.map.getLayer('coverageCheckGraphics_point').graphics[0]);
var chkpnt = map.getLayer('coverageCheckGraphics_point').graphics[0].geometry;
var query = new Query();
var fiberCovCompletionFlagCheck = mySelfSearch.fiberCoverageCompletion;
query.geometry = chkpnt;
query.where = " 1=1 ";
query.returnGeometry = true;
query.spatialRelationship = "esriSpatialRelIntersects";
var queryTaskFiber = new QueryTask(mySelfSearch.queryURLFiber);
query.outFields = ['*'];
queryTaskFiber.execute(query, mySelfSearch.reportMyCoverage, function (error) { console.log(getADBDate() + "Error occured in queryTaskFiber.execute " + error.message); });
mySelfSearch.fiberCoverageCompletion=false;
} catch (e) {
console.log("Error occured in check coverage " + e.message);
reportMyCoverage: function (result)
reportMyCoverage: function (result) {
var isCovered = result.features.length > 0;
if (isCovered) {
mySelfSearch.fiberCoverage = 'TRUE';
} else {
mySelfSearch.fiberCoverage = 'FALSE';
Adeeb,
Sure here is how. This is call JS Closure. You pass the point object to the result function.
function(result){
mySelfSearch.reportMyCoverage(result, chkpnt);
function (error) {
reportMyCoverage: function (pntGeom, result) {
if (isCovered) {
console.log(pntGeom);
} else {
