How to fix " Error: Can't resolve '@arcgis/core/MapView' "
2872
01-04-2022 03:13 AM
ShainaAlia
i am trying to display a map with ArcGis Js Api in ReactJS
import Map from "@arcgis/core/Map";
import WebMap from "@arcgis/core/WebMap";
import MapView from "@arcgis/core/MapView";
function Test() {
    const webmap = new WebMap({
        portalItem: {
       * Set the WebMap instance to the map property in a MapView.
      const view = new MapView({
        map: webmap,
        container: "viewDiv"
    return(
        <div>
            <div id="viewDiv"></div>
        </div>
  export default Test;
but i get the error " Error: Can't resolve '@arcgis/core/MapView' "
i tried to fix the error with re-installing the module @arcgis/core, Webpack and others but i couldn't fix it
can someone help me please ?
Kishore
@ShainaAlia  - First install the ArcGIS library in the react app folder using
npm install @arcgis/core
Please follow the blog from @ReneRubalcava  to get the step by step process create-react-app
Regards,
Kishore
JoseBanuelos
@ShainaAlia ,
The path should be "@arcgis/core/views/MapView" in the MapView import.
Jose
AzeemIzhar
Your path to MapView incorrect, you miss views directory. Try import MapView from "@arcgis/core/views/MapView"; like in official docs
