How to create custom recenter button
1840
8
03-04-2020 10:06 PM
rsharma
Occasional Contributor III
Hi I am trying to get custom recenter button and basemap 3 custom button like below image. Is their any example
FC_Basson
MVP Regular Contributor
Use "dojo/dom-construct" in the require and define it in the function variables like domConstruct.
Then after you have initialised your view you can create the button.
// create DOM object
recenterBtn = domConstruct.toDom("<div class='map-button esri-component esri-locate esri-widget--button esri-widget' role='button' title='Recenter'><span aria-hidden='true' role='presentation' class='esri-icon esri-icon-globe'></span></div>");
// add to view
view.ui.add(recenterBtn, "bottom-right");
// add button click listener
recenterBtn.addEventListener('click', recenterFunction);‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
Use the MapView goTo() function to set the center view: MapView | ArcGIS API for JavaScript 4.14
Add your own CSS to style it as you wish.
Also see the Custom Recenter Widget | ArcGIS API for JavaScript 4.14 example for the TypeScript version.
FC_Basson
What version of the API are you using? 3.x or 4.x?
rsharma
4.x
FC_Basson
// add to view
FC_Basson
You must still create the recenter function e.g.
function recenterView(){
  view.goTo({
    center: [-126, 49],
    zoom: 15
which you then call with the listener
recenterBtn.addEventListener('click', recenterView);
rsharma
OK now it is clickable, but it do only zoom where ever it is on world map, it do not goto to that exact location of x and y axis(lat,long)
view.when(function() {
          // Add the boundary polygon and new lot polygon graphics
          addGraphics();
          var recenterBtn = domConstruct.toDom("<div class='map-button esri-component esri-locate esri-widget--button esri-widget' role='button' title='Recenter'><span aria-hidden='true' role='presentation' class='esri-icon esri-icon-globe'></span></div>");
          // add to view
                view.goTo({
                center: ['<?=$map_xy_coordinate['x']?>', '<?=$map_xy_coordinate['y']?>'],
                  zoom: 15
rsharma
Its done, it was some minor error, btw thanks alot for ur kind efforts.
So now i will create  basemap buttons with the same method now, but what method do i call on click to change basemap
FC_Basson
It depends on how many basemaps you want to use.
Have a look at the documentation for BasemapToggle | ArcGIS API for JavaScript 4.14 and the BasemapGallery | ArcGIS API for JavaScript 4.14 widgets.
Otherwise the function for switching basemaps can be simple as:
function setbasemap(basemap){
   map.basemap = basemap;
and attach the click event to the buttons
basemapBtn.addEventListener('click', function(){
  setbasemap('hybrid');
rsharma
Thanks Basson it worked for me
