How to check if a polyline is partially inside an extent ?
945
04-27-2021 06:08 AM
SelectivelySocial
New Contributor III
Is there a way to check if a polyline/line is partially inside an extent ?
I tried extent.contains,  but it only returns true if the whole line is inside the extent,even if little part of it lies outside the extent then it return false. Is there a way to solve this ?
Thanks.
jcarlson
MVP Esteemed Contributor
You want intersects, which will return true if any part of the line is within the extent.
Edit: if you want to check for being partially within only, you could check that intersects returns true and contains returns false.
- Josh Carlson
Kendall County GIS
jcarlson
- Josh Carlson
Kendall County GIS
SelectivelySocial
New Contributor III
@jcarlson Thanks !!
I completely missed this method in documentation, feel really stupid.
DavidPike
MVP Frequent Contributor
I'd probably look at if extent.disjoint True/False which may be faster than an intersection (just a guess though).
SelectivelySocial
New Contributor III
Though the data is not much, I'll still look into this.
Thanks.
