How to add bounding box (W, E, S, N) dataset as feature layer in SceneView
1340
09-03-2021 11:30 PM
KrishnakanthYachareni
New Contributor II
I'm a complete beginner to the Esri API and I have a dataset that doesn't have coordinates, instead, it has the following bounding points. I'd like to imports that dataset as a feature layer in the base map. I see Extent (https://developers.arcgis.com/javascript/latest/api-reference/esri-geometry-Extent.html) not seems appropriate for my requirement. Could anyone help here?
BoundingBox {
       WestBLongitude-120.355
       EastBLongitude-120.355
       SouthBLatitude: 10.301
       NorthBLatitude: 10.301869
Is there any way that we can build a feature layer without having coordinates but just with bounding values?
David_Brooks
MVP Regular Contributor
New Contributor II
Thanks for the response but to draw the above suggestions required an array of points like building a polygon, but I don't have points in dataset.
David_Brooks
@KrishnakanthYachareni sorry, can you explai in more detail what you have?
If you want to make a rectangle from bounding coordinates then surely you just build a geometry from those:
Pont1 = xMin, yMin
Point2 = xMin, yMax
Point3 = xMax, yMax
Point 4 = xMax, yMin
David
..Maps with no limits..
