How to access the availableCreateTools property of Sketch Widget
635
08-21-2019 04:46 PM
NickStapler
New Contributor II
I am trying to access this property so that i can toggle off certain or all create buttons like the point and circle buttons.
I attempted to utilize this property but found that it was not on the created object:
SaschaBrunnerCH
Hi Nick,
This property can only be set once on creation the widget (see: Sketch | ArcGIS API for JavaScript 4.12 ). Just add
availableCreateTools: ["point", "polygon"]
Full sample:
<html>
  <head>
    <meta charset="utf-8" />
    <meta
      name="viewport"
      content="initial-scale=1,maximum-scale=1,user-scalable=no"
    <title>Sketch widget - 4.12</title>
    <link
      rel="stylesheet"
      href="https://js.arcgis.com/4.12/esri/themes/light/main.css"
    <script src="https://js.arcgis.com/4.12/"></script>
    <style>
      html,
      body,
      #viewDiv {
        padding: 0;
        margin: 0;
        height: 100%;
        width: 100%;
    </style>
    <script>
      require([
        "esri/widgets/Sketch",
        "esri/Map",
        "esri/layers/GraphicsLayer",
        "esri/views/MapView"
      ], function(Sketch, Map, GraphicsLayer, MapView) {
        const layer = new GraphicsLayer();
        const map = new Map({
          basemap: "streets",
          layers: [layer]
        const view = new MapView({
          container: "viewDiv",
          map: map,
          zoom: 5,
          center: [90, 45]
        const sketch = new Sketch({
          layer: layer,
          view: view,
        console.log(sketch.availableCreateTools);
        view.ui.add(sketch, "top-right");
    </script>
  </head>
  <body>
    <div id="viewDiv"></div>
  </body>
</html>
SaschaBrunnerCH
Hi Nick,
Full sample:
<html>
  <head>
    <meta
      name="viewport"
    <link
      rel="stylesheet"
    <style>
      html,
      body,
      #viewDiv {
        padding: 0;
        margin: 0;
        height: 100%;
        width: 100%;
    </style>
    <script>
      require([
        "esri/Map",
          basemap: "streets",
          layers: [layer]
          map: map,
          zoom: 5,
          center: [90, 45]
          layer: layer,
          view: view,
    </script>
  </head>
  <body>
  </body>
</html>
