How can we add MapImageLayer into webscene Portal item as in two 2d we can add into Map so how we can add on 3D ?
407
08-18-2019 09:40 PM
AnupamSharma
New Contributor III
Here is snap of code which is not working
Thank you in advance
Tags (1)
SaschaBrunnerCH
It is the same for 2D and 3D.
See: MapImageLayer | ArcGIS API for JavaScript 4.12
Section: Reference an ArcGIS portal Item ID
// references an ArcGIS Online item pointing to a Map Service Layer
var layer = new MapImageLayer({
  portalItem: {  // autocasts as esri/portal/PortalItem
map.add(layer);  // adds the layer to the map‍‍‍‍‍‍‍‍‍‍‍‍‍‍
by Anonymous User
Not applicable
Hi Sharma,
I create sample code for you, below is the codepen url
https://codepen.io/thanhtetaung/pen/xxKEKoe
map.layers.add(permitsLayer)
or
Initialized map with layers, that will work
