Help!! TOC not showing up.....
4241
16
09-29-2014 07:16 AM
JenniferZumbado-Hannibal1
I'm trying to learn programming with ArcGIS API for Javascript. This is my first attempt at this so please excuse my ignorance.
Anyhow, what I want is very simple...use a dynamic map service with 23 layers (yes...I know...but my audience "needs them all") to be able to check off/on within a TOC.
Thus, I downloaded the Table of Contents (TOC)/Legend Widget for JavaScript API and incorporated into my script. I haven't been very successful at all. I'm using Notepad ++ and have tried opening it with several different browsers (Firefox v. 31, Chrome v. 37, & IE v.8). Debugging with Chrome's developer tools mostly.
I've put the TOC widget folder and .html on my webserver to test. No results! Not happening! What I'm I doing wrong?
This is my script so far:
<!DOCTYPE html>
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
    <meta http-equiv="X-UA-Compatible" content="IE=edge">
    <meta name="viewport" content="initial-scale=1, maximum-scale=1, user-scalable=no">
    <title>Blabla....</title>
  <link rel="stylesheet" href="http://js.arcgis.com/3.10/js/dojo/dijit/themes/claro/claro.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.10/js/esri/css/esri.css">
  <link rel="stylesheet" type="text/css" href="../src/agsjs/css/agsjs.css" />
    <style>
      html, body
    </style>
  <script src="http://js.arcgis.com/3.10/">
  </script>
    <script type="text/javascript">
      // helpful for understanding dojoConfig.packages vs. dojoConfig.paths:
     // http://www.sitepen.com/blog/2013/06/20/dojo-faq-what-is-the-difference-packages-vs-paths-vs-aliases/
      var dojoConfig = {
      paths: {
      //if you want to host on your own server, download and put in folders then use path like:
      agsjs: location.pathname.replace(/\/[^/]+$/, '') + '/../src/agsjs'
    </script>
  var map, toc, dynaLayer1;
       require(["dojo/_base/connect",
     "dojo/on",
        "esri/map",
        "esri/dijit/Geocoder",
      "esri/geometry/Extent",
      "esri/layers/FeatureLayer",
      "esri/layers/ArcGISTiledMapServiceLayer",
  "esri/symbols/SimpleFillSymbol",
     "esri/renderers/ClassBreaksRenderer",
     "agsjs/dijit/TOC",
        "esri/graphic",
        "esri/symbols/SimpleMarkerSymbol",
        "esri/geometry/screenUtils",
        "dojo/dom",
        "dojo/dom-construct",
        "dojo/query",
        "dojo/_base/Color",
  "esri/dijit/Scalebar",
  "esri/dijit/HomeButton",
  "esri/dijit/OverviewMap",
  "dijit/layout/BorderContainer",
  "dijit/layout/ContentPane",
  "esri/dijit/BasemapGallery",
  "esri/arcgis/utils",
  "dojo/parser",
  "esri/layers/ArcGISDynamicMapServiceLayer",
  "dojo/fx",
        "dojo/domReady!"
        ], function(connect, on,
        Map, Geocoder, Extent, FeatureLayer, ArcGISTiledMapServiceLayer, SimpleFillSymbol,
  ClassBreaksRenderer, TOC,
        Graphic, SimpleMarkerSymbol, screenUtils,
        dom, domConstruct, query, Color, Scalebar, HomeButton, OverviewMap,
  BorderContainer, ContentPane, BasemapGallery, arcgisUtils, parser, ArcGISDynamicMapServiceLayer
     // call the parser to create the dijit layout dijits
              parser.parse(); // note djConfig.parseOnLoad = false;
        // create a map
        var map = new Map("map", {
          sliderOrientation : "horizontal",
   basemap: "topo",
          center: [-93.745776,32.513614],
          zoom: 14
  //variable REST service Shreveport as a layer
  dynaLayer1 = new ArcGISDynamicMapServiceLayer("http://noonecares/rest/services/MapServer", {
        opacity: 0.9
alert("1");  //shows up when it runs
  //Add a TOC widget
  map.on('layers-add-result', function(evt){
         // overwrite the default visibility of service.
         // TOC will honor the overwritten value.
        dynaLayer1.setVisibleLayers([3, 7, 8, 23]);
          toc = new TOC({
           map: map,
           layerInfos: [{
            layer: dynaLayer1,
            title: "Base Map"
            //collapsed: true, // whether this root layer should be collapsed initially, default false.
            //slider: true, // whether to display a transparency slider.
  //autoToggle: true //whether to automatically collapse when turned off, and expand when turn on for groups layers. default true.
           }, 'tocDiv');
           toc.startup();
alert("2"); //it skipped when it runs
    toc.on('load', function(){
alert("3"); //it skipped when it runs
                if (console)
                    console.log('TOC loaded');
                    dom.byId("InsertNewLayer").disabled = false;
          map.addLayers([dynaLayer1]);
alert("4"); //shows up when it runs
    on(dom.byId("SetOpacity"), 'click', function(evt){
                if (dynaLayer1 != null) {
                  dynaLayer1.setOpacity(0.2);
  //adding geocoder widget
        var geocoder =  new Geocoder({
          arcgisGeocoder: {
            placeholder: "Find an address"
          autoComplete: true,
          map: map
        }, dom.byId("search"));
        map.on("load", enableSpotlight);
        geocoder.on("select", showLocation);
        geocoder.on("clear", removeSpotlight);
  //adding scalebar widget
     var scalebar = new Scalebar({
          map: map,
   attachTo: "bottom-left",
          scalebarUnit: "dual"
    //adding home button widget
    var home = new HomeButton({
    map: map
    }, "HomeButton");
    home.startup();
    //adding overview map widget
    var overviewMapDijit = new OverviewMap({
        map: map,
        visible: true,
  attachTo: "bottom-right",
  opacity: .40
       overviewMapDijit.startup();
    //add the basemap gallery, in this case we'll display maps from ArcGIS.com including bing maps
       var basemapGallery = new BasemapGallery({
        showArcGISBasemaps: true,
        map: map
        }, "basemapGallery");
        basemapGallery.startup();
        basemapGallery.on("error", function(msg) {
        console.log("basemap gallery error:  ", msg);
        //showing Lat, Long location on the bottom of map
        function showLocation(evt) {
          map.graphics.clear();
          var point = evt.result.feature.geometry;
          var symbol = new SimpleMarkerSymbol().setStyle(
            SimpleMarkerSymbol.STYLE_SQUARE).setColor(
            new Color([255,0,0,0.5])
          var graphic = new Graphic(point, symbol);
          map.graphics.add(graphic);
          map.infoWindow.setTitle("Search Result");
          map.infoWindow.setContent(evt.result.name);
          map.infoWindow.show(evt.result.feature.geometry);
          var spotlight = map.on("extent-change", function(extentChange) {
            var geom = screenUtils.toScreenGeometry(map.extent, map.width, map.height, extentChange.extent);
            var width = geom.xmax - geom.xmin;
            var height = geom.ymin - geom.ymax;
            var max = height;
            if ( width > height ) {
                max = width;
            var margin = '-' + Math.floor(max/2) + 'px 0 0 -' + Math.floor(max/2) + 'px';
            query(".spotlight").addClass("spotlight-active").style({
              width: max + "px",
              height: max + "px",
              margin: margin
            spotlight.remove();
        //adding point spot holder
        function enableSpotlight() {
          var html = "<div id='spotlight' class='spotlight'></div>"
          domConstruct.place(html, dom.byId("map_container"), "first");
        //removing point spot holder
  function removeSpotlight() {
          query(".spotlight").removeClass("spotlight-active");
          map.infoWindow.hide();
    </script>
  </head>
  <body class="claro">
  <div id="content" data-dojo-type="dijit/layout/BorderContainer" design="headline" gutters="true" style="width: 100%; height: 100%; margin: 0;">
    <div id="header" data-dojo-type="dijit/layout/ContentPane" region="top">
     <div>
             <ul style="margin:15px">
              <b>Blabla....</b>
    <div id="search"></div>
             </ul>
        </div>
  </div>
  <div data-dojo-type="dijit/layout/ContentPane" id="leftPane" region="left" splitter="true">
        <div id="tocDiv">
        </div>
    </div>
  <div id="map" data-dojo-type="dijit/layout/ContentPane" region="center">
     <div id="HomeButton"></div>
  <div style="position:absolute; right:50px; top:10px; z-Index:999;">
  <div data-dojo-type="dijit/TitlePane"
             data-dojo-props="title:'Switch Basemap', closable:false, open:false">
           <div data-dojo-type="dijit/layout/ContentPane" style="width:380px; height:280px; overflow:auto;">
               <div id="basemapGallery"></div>
       </div>
         </div>
     </div>
  </div>
  </div>
  </body>
</html>
KenBuja
This might be a question for Timothy Hales
TimothyHales
Esri Notable Contributor
Jennifer Zumbado-Hannibal
When you are logged in you should see a "Correct Answer" button for each reply.
RobertScheitlin__GISP
Jennifer,
   You need to ensure that you are logged in and that you click on the Actions Menu from the actually content page and not from the message in your inbox.
Sorry Timothy Hales‌ and Robert Scheitlin but I do not see that button.
I'm not in my inbox. I'm actually on the thread post itself and again....all I see in the Actions drop down menu is 'Report Abuse'.
I'm logged in with my user name and yet I can't post this as resolved.
Should I contact ESRI Support to do a screen share?
Jennifer,
   You would also only get this option (the option to mark as "Correct Answer") if you are the original poster.
TimothyHales
This issue here is that you have used two different accounts within this thread. The question was originally posted with 'cosgisadmin' and you are currently logged in using 'jenzumbado'. You will need to be logged in with 'cosgisadmin' to mark the question as correct.
You were right Timothy Hales‌ I was logged into my personal account and not my organization account. I wish I can name them differently.
Thanks so much for all your help guys. Sorry for being such a pain. Again, I'm new at this
