HELP! SimpleFillSymbol and Search Widget modification
3125
7
07-23-2015 07:02 AM
JamesFitzgerald
Occasional Contributor II
I need direction. I want to modify Search using a suggestion template | ArcGIS API for JavaScript by incorporating the SimpleFillSymbol and SimpleLineSymbol. I feel I am close but still missing code. It will load but now the search box disappears. THANKS
var search = new Search({
        sources: [{
           featureLayer: new FeatureLayer("http://services.arcgis.com/HYLRafMc4Ux6DA8c/arcgis/rest/services/Parks_Search/FeatureServer/1", {
             mode: FeatureLayer.MODE_ONDEMAND,
             outFields: ["*"],
             infoTemplate: new InfoTemplate("Identify County Parks",
             "Park Name: ${Name}</br>ParK Ownership: ${ParkType}</br>"),
             sfs: new SimpleFillSymbol(SimpleFillSymbol.STYLE_Null,
             new SimpleLineSymbol (SimpleLineSymbol.STYLE_SOLID, new Color([255,0,0]), 2),
             new Color([255,255,0,0,0.5]))
        map: map
      },  "search");
      search.startup();
      map.addLayer(featureLayer);
RobertScheitlin__GISP
James,
   There is no simpleFill option for the Search widget constructor... Are you looking for the "highlightSymbol"?
James,
   It sounds like you are having an issue with your requires and vars being out of order. Can you post your code?
JamesFitzgerald
<!DOCTYPE html>
<html>
<head>
  <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
  <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no" />
  <title>Search with Suggestion Template</title>
    <link rel="stylesheet" href="http://js.arcgis.com/3.14/dijit/themes/claro/claro.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.14/esri/css/esri.css">
    <script src="http://js.arcgis.com/3.14/"></script>
  <style>
    html,
    body,
    #map {
      height: 100%;
      width: 100%;
      margin: 0;
      padding: 0;
    #search {
      display: block;
      position: absolute;
      z-index: 2;
      top: 20px;
      left: 74px;
   </style>
  <script>
   require(["esri/map","esri/geometry/Extent", "esri/layers/ArcGISTiledMapServiceLayer", "esri/dijit/Search",  "esri/layers/FeatureLayer",
           "esri/InfoTemplate","esri/symbols/SimpleFillSymbol","esri/symbols/SimpleLineSymbol", "dojo/domReady!"],
   function (Map, Extent,ArcGISTiledMapServiceLayer, Search,    FeatureLayer, InfoTemplate, SimpleFillSymbol, SimpleLineSymbol) {
      var map = new Map("map", {
        extent: new Extent({xmin: -9464867.586310409, ymin: 3988479.973394642, xmax: -9359211.763174301, ymax: 4048458.624373842,spatialReference: {wkid: 102100}})
      var basemap = new ArcGISTiledMapServiceLayer("http://services.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer");
        map.addLayer(basemap);
      var featureLayerParks = new FeatureLayer("http://services.arcgis.com/HYLRafMc4Ux6DA8c/arcgis/rest/services/Parks_Search/FeatureServer/1", {
         opacity:.5,
         visible: FeatureLayer.isVisibleAtMapScale=true
      map.addLayer(featureLayerParks);
        sources: [{
             new Color([255,255,0,0,0.5])),
             outFields: ["*"],
        map: map
      },  "search");
      search.startup();
   </script>
</head>
<body>
  <div id="search"></div>
  <div id="map"></div>
</body>
</html>
James,
   you are missing your require and var  for "esri/Color"
JamesFitzgerald
Hey,
It loaded correctly but seemed to skip the simpleFill. Do I need to set it? Add it to featureLayer? Not sure. Thank You for your help!
        sources: [{
           simpleFill: new SimpleFillSymbol(SimpleFillSymbol.STYLE_Null,
             outFields: ["*"],
        map: map
      },  "search");
      search.startup();
James,
JamesFitzgerald
Thanks, I am new to arcGIS API for JavaScript. I am beginning to understand.
Thanks again!
JamesFitzgerald
Hey again,
enableHighlight worked! It definitely took way too long seek help from GeoNet! Very easy!
James
