Hello All,
Trying to add the easy navigation widget to a scene. Cant seem to get it to work. would appreciate someone pointing out what im doing wrong. appreciate the help.
Looks like you were missing two modules (dojo/dom and dojo/on) and also the code for the easy navigation needed to be moved into the reguire function. Here's an updated bit of code that should work.
Thanks Kelly! That's awesome. Appreciate your explanation as well.
