Hello i am using search widget for 3d where as per api i have also declared feature layer url but the output of search result showing somewhere else in a wrong position in the map
475
07-24-2019 12:00 AM
AnupamSharma
i am getting the below error,Thank you in advance
dojo.js:334 [esri.views.3d.state.ViewStateManager] #goTo() Failed to create camera from target, no layerview has been found for the layer
FlavieMoraux
I have the same problem since upgrading API version (4.9 to 4.12).
FlavieMoraux
This workaround is working for me (with API 4.12) :
1) Desactivate zoom on result
Foreach widget source set property "autoNavigate" to false
2) Zoom programatically on result
on(widget, "search-complete", function(event) {
      if (event.results[0].results[0].feature.geometry.type === "point") {
                  view.goTo({
                        target : event.results[0].results[0].feature.geometry,
                        zoom : 15
      } else {
                  view.goTo({event.results[0].results[0].extent});
