Grid- Find task based on Radio Button Selection
5202
01-05-2015 01:00 PM
CraigLinn
New Contributor III
I am looking for the best way to run a find task based on a radio button selection and export that to a grid. Thus I simply choose the correct radio button I want to use and search layer and populate results.  Thanks,
<!DOCTYPE html>
<html>
  <head>
    <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
    <title>Display Find Task results in Dojo DataGrid</title>
    <link rel="stylesheet" href="http://js.arcgis.com/3.12/dijit/themes/claro/claro.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.12/dojox/grid/resources/Grid.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.12/dojox/grid/resources/claroGrid.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.12/esri/css/esri.css">
    <style>
      html, body { height: 100%; width: 100%; margin: 0; padding: 0; }
    </style>
    <script src="http://js.arcgis.com/3.12/"></script>
    <script>
      require([
        "esri/map",
        "esri/tasks/FindTask",
        "esri/tasks/FindParameters",
        "esri/symbols/SimpleMarkerSymbol",
        "esri/symbols/SimpleLineSymbol",
        "esri/symbols/SimpleFillSymbol",
        "esri/Color",
        "dojo/on",
        "dojo/dom",
        "dijit/registry",
        "dojo/_base/array",
        "dojo/_base/connect",
        "dojox/grid/DataGrid",
        "dojo/data/ItemFileReadStore",
        "dijit/form/Button",
        "dojo/parser",
        "dijit/layout/BorderContainer",
        "dijit/layout/ContentPane",
        "dojo/domReady!"
      ], function(
        Map, FindTask, FindParameters, SimpleMarkerSymbol, SimpleLineSymbol, SimpleFillSymbol,
        Color, on, dom, registry, arrayUtils, connect, DataGrid, ItemFileReadStore, Button, parser
        var findTask, findParams;
        var map, center, zoom;
        var grid, store;
        parser.parse();
        registry.byId("search").on("click", doFind);
        center = [-83.266, 42.568];
        zoom = 11;
        map = new esri.Map("map", {
          basemap: "streets",
          center: center,
          zoom: zoom
        //Create Find Task using the URL of the map service to search
        findTask = new FindTask("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/TaxParcel/TaxParcelQuery/MapServer/");
findTask = new FindTask("http://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer/0");
        map.on("load", function () {
          //Create the find parameters
          findParams = new FindParameters();
          findParams.returnGeometry = true;
          findParams.layerIds = [0];
          findParams.searchFields = ["OWNERNME1", "OWNERNME2"];
          findParams.outSpatialReference = map.spatialReference;
          console.log("find sr: ", findParams.outSpatialReference);
        function doFind() {
          //Set the search text to the value in the box
          findParams.searchText = dom.byId("ownerName").value;
          findTask.execute(findParams, showResults);
        function showResults(results) {
          //This function works with an array of FindResult that the task returns
          map.graphics.clear();
          var symbol = new SimpleFillSymbol(
            SimpleFillSymbol.STYLE_SOLID,
            new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([98, 194, 204]), 2),
            new Color([98, 194, 204, 0.5])
          //create array of attributes
          var items = arrayUtils.map(results, function (result) {
            var graphic = result.feature;
            graphic.setSymbol(symbol);
            map.graphics.add(graphic);
            return result.feature.attributes;
          //Create data object to be used in store
          var data = {
            identifier : "PARCELID", //This field needs to have unique values
            label : "PARCELID", //Name field for display. Not pertinent to a grid but may be used elsewhere.
            items : items
          //Create data store and bind to grid.
          store = new ItemFileReadStore({
            data : data
          var grid = registry.byId("grid");
          grid.setStore(store);
          grid.on("rowclick", onRowClickHandler);
          //Zoom back to the initial map extent
          map.centerAndZoom(center, zoom);
        //Zoom to the parcel when the user clicks a row
        function onRowClickHandler(evt) {
          var clickedTaxLotId = evt.grid.getItem(evt.rowIndex).PARCELID;
          var selectedTaxLot = arrayUtils.filter(map.graphics.graphics, function (graphic) {
            return ((graphic.attributes) && graphic.attributes.PARCELID === clickedTaxLotId);
          if ( selectedTaxLot.length ) {
            map.setExtent(selectedTaxLot[0].geometry.getExtent(), true);
    </script>
  </head>
  <body class="claro">
  <div data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline'"  style="width:100%;height:100%;margin:0;">
    <div data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'top'" style="height:40px;">
      Owner name: <input type="text" id="ownerName" size="60" value="Katz" />
          <button id="search" data-dojo-type="dijit.form.Button" type="button" data-dojo-attach-point="button" >Search
          </button>
          <input type="radio" id="radLayer1" name="rbLayer" value="rbLayerONE" checked>Layer 1
          <input type="radio" id="radLayer2" name="rbLayer" value="rbLayerTWO" checked>Layer 2
    </div>
    <div id="map" data-dojo-props="region:'center'" data-dojo-type="dijit/layout/ContentPane" style="border:1px solid #000;"></div>
    <div data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'bottom'" style="height:150px;">
     <table data-dojo-type="dojox/grid/DataGrid" data-dojo-id="grid"  id="grid" data-dojo-props="rowsPerPage:'5', rowSelector:'20px'">
      <thead>
        <tr>
          <th field="PARCELID">Parcel ID</th>
          <th field="OWNERNME1" >Owner 1</th>
          <th field="OWNERNME2">Owner 2</th>
          <th field="RESYRBLT ">Year Built</th>
          <th field="SITEADDRESS" width="100%">Address</th>
        </tr>
      </thead>
    </table>
    </div>
  </div>
  </body>
</html>
JakeSkinner
Esri Esteemed Contributor
One way you could do this is use two different Grids in an accordion container.  To use two different services, you will just need to place the FindTask within each function (i.e. in this example, findState and findCity).
Edit fiddle - JSFiddle
JakeSkinner
Hi Craig,
You can do this by adding the findParams.layerIds to the doFind function.  Ex:
function doFind() {
  if(registry.byId("radLayer1").checked){
    findParams.layerIds = [1];
  else if(registry.byId("radLayer2").checked){
    findParams.layerIds = [4];
Here is a JS Fiddle of a working example.
CraigLinn
New Contributor III
Thanks for your support! That does help.  I should have been more detailed in my question. I have different rest services associated with each radio button. I would have a different table and search variable for each rest service.   I was thinking about creating multiple find task with multiple table divs and with the radio button selected toggle all tables except that one, the same goes for search bar. What are your thoughts on that?
<!DOCTYPE html>
<html>
<head>
  <meta http-equiv="content-type" content="text/html; charset=UTF-8">
  <title> - jsFiddle demo</title>
      <link rel="stylesheet" type="text/css" href="http://js.arcgis.com/3.12/dijit/themes/claro/claro.css">
      <link rel="stylesheet" type="text/css" href="http://js.arcgis.com/3.12/dojox/grid/resources/Grid.css">
      <link rel="stylesheet" type="text/css" href="http://js.arcgis.com/3.12/dojox/grid/resources/claroGrid.css">
      <link rel="stylesheet" type="text/css" href="http://js.arcgis.com/3.12/esri/css/esri.css">
      <script type='text/javascript' src="http://js.arcgis.com/3.12/"></script>
  <style type='text/css'>
  </style>
<script type='text/javascript'>//<![CDATA[
window.onload=function(){
require([
        "esri/map",
        "esri/Color",
        "dojo/on",
        "dojo/dom",
        "dijit/registry",
        "dojo/_base/array",
        "dojo/parser",
        "dijit/form/RadioButton",
        "dojo/domReady!"
      ], function(
        var grid, store;
        parser.parse();
        center = [-85.7667, 38.2500];
        zoom = 11;
          basemap: "streets",
          center: center,
          zoom: zoom
        findTask = new FindTask("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Louisville/LOJIC_PublicSafety_Louisville/...");
        findTask2 = new FindTask("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer"); //0
      //findTask2 Fields    ObjectID  State_FIPS  TRACT  BLOCK
          findParams.searchFields = ["NAME"];
        function doFind() {
        //  else if(registry.byId("radLayer2").checked){
        //    findParams.layerIds = [3];
          var data = {
            identifier : "OBJECTID", //This field needs to have unique values
            label : "OBJECTID", //Name field for display. Not pertinent to a grid but may be used elsewhere.
            items : items
            data : data
          var clickedTaxLotId = evt.grid.getItem(evt.rowIndex).OBJECTID;
            return ((graphic.attributes) && graphic.attributes.OBJECTID === clickedTaxLotId);
           var centerClickRow = [selectedTaxLot[0].geometry.getLongitude(), selectedTaxLot[0].geometry.getLatitude()];
   var zoomClickRow = 14;
      map.centerAndZoom(centerClickRow, zoomClickRow);
           // map.setExtent(selectedTaxLot[0].geometry.getExtent(), true);
</script>
</head>
<body>
      ID: <input type="text" id="ownerName" size="60" value="a" />
          </button>
            <input type="radio" name="rbLayer" value="rbLayerONE" checked="checked" id="radLayer1" data-dojo-type="dijit/form/RadioButton">Fire Stations
            <input type="radio" name="rbLayer" value="rbLayerTWO" id="radLayer2" data-dojo-type="dijit/form/RadioButton"> Layer 2
    </div>
      <thead>
        <tr>
          <th field="OBJECTID">ID</th>
          <th field="NAME">Name</th>
          <th field="ADDRESS"width="30%">Address</th>
          <th field="LFD_DIST"width="100%">City</th>
        </tr>
      </thead>
    </table>
    </div>
  </div>
  </body>
</body>
</html>
JakeSkinner
